04-27-2018, 08:58 PM | #1 |
Alternator or regulator over charging
Greetings , the battery on 70 c20 was completly dead the other day must have left something on , charged it put it back in over night and is holding charge ,now i tested the battery with a volt meter truck running and it’s 15.5 seems high to me could this possibly be the voltage regulator ? Thank you in advance
04-27-2018, 09:43 PM | #2 |
Re: Alternator or regulator over charging
hi my 70 gmc used to charge about 15.5 also. if you have an older external voltage regulator they can be adjusted. google it and learn how. its very easy I,ve done two. you just have to make very small adjustments. I got both of mine down to 14.25 or so. and as the battery charges it comes down even more. maybe 13.8- 14.0 hope this helps. BROWN 70
04-27-2018, 10:55 PM | #3 |
Who Changed This?
15.5 is in the charging range, but a bit high. Maybe you should shut it off and look to see if something is still draining the battery, or if it is fully charged. A fully charged battery is 12.6V. Minimum charging voltage is 13.5V. Anything below that, you have a charging system problem. Charging at 15.5 seems to me like the system is picking up from a low charge state.
04-28-2018, 12:19 PM | #4 | |
Posted via Mobile Device |
04-28-2018, 03:54 PM | #5 |
Who Changed This?
I don't have the CRM on hand but I do have the Chilton's manual, and they are saying 13.8-14.8V. So, higher than it should be. If it has an external regulator, you can adjust the voltage down a little. You'll need a manual for all the steps. Someone was gracious enough to load up the CRM as .pdf files, but I don't have a link.
04-28-2018, 07:35 PM | #6 | |
04-28-2018, 07:41 PM | #7 |
Electronic regulators are available if the mechanical adjustment doesn't work. I think the model starts w/ VR1 which will get you close.
04-28-2018, 09:57 PM | #8 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=558016 EDIT: OK, I just looked at 3 voltage regulators from my stash. One was an electronic (obviously not original) replacement part. The other 2, both from 67-72 trucks, one my original, were different inside. One appeared adjustable, the other not so obvious. There's also a pretty high likelihood that yours may have been replaced over the years. Last edited by FirstOwner69; 04-28-2018 at 10:21 PM. |
04-28-2018, 10:19 PM | #9 | |
Who Changed This?
