Old 08-14-2018, 12:04 AM   #1
Tkrysl
Gas Tank Issue
Evening,
Today after filling up for the first time, I smelled gas driving home. After investigation, it is coming from what looks to be some sort of breather return on the sending unit.
Is there a cap that belongs on this open port? It's a terrible picture but the shiny piece circled with yellow has an open end.
Appreciate your willingness to give this noob some knowledge.
Tkrysl is offline   Reply With Quote
Old 08-14-2018, 01:03 AM   #2
billthompson
Re: Gas Tank Issue
if memory serves one of those is a vent line that goes to a folded piece of tubing assembly that runs up in the space of the cab at the passenger side of the tank, directly behind the passenger door latch. seems like the fuel line exits the cab in the floor over there too. dont qoute me cause its been years since i messed with a tank in a pickup cab. if you dont find anything over there let me know and ill dig though the books when i get to the shop
billthompson is offline   Reply With Quote
Old 08-14-2018, 01:26 AM   #3
billthompson
Re: Gas Tank Issue
i looked at lmc catalog and think that line may be the one that goes up to the carcoal canester. either way its a vent line and needs to be plumbed outside the vehicle
or capped off or youll always have fumes
Old 08-14-2018, 09:06 AM   #4
ncpetersc
ncpetersc's Avatar
Re: Gas Tank Issue
I think the tubes circled in red are go to that vent tube up the passenger side of the cab.
The "uncapped" tube is usually connected to another fuel line coming back from the fuel pump.
Maybe you have a fuel pump with out this connection (2 lines vs. 3 lines)?
Also, I cannot tell if there is a hose connected between the neck and the tank on the drivers side?
ncpetersc is offline   Reply With Quote
Old 08-14-2018, 09:09 AM   #5
cerial
cerial's Avatar
Re: Gas Tank Issue
You have a 71/72 eec tank. The picture below is how I am running my lines. You plug that sending unit line. Running the lines as above will avoid fuel entering the vent line if on your side/roof.
url=https://imgbb.com/][/url]
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 08-14-2018, 09:10 AM   #6
jbarron
Re: Gas Tank Issue
The port on the sending unit is for a return line from the fuel pump.
If you do not have a fuel pump with a return then block it off.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 08-14-2018, 09:11 AM   #7
ncpetersc
ncpetersc's Avatar
Re: Gas Tank Issue
There were different tanks and fuel setups. I think the tank you have is referred to as "with EEC" which is some sort of emissions control and is associated with having the charcoal canister in the engine bay.
There are different sending units as well. Some only have the fuel supply line, some have two connections like the one you (and I) have. It's sometimes referred to as a 'return' line, but I have been told it also serves more of a venting purpose, but it would connect to a separate fuel line running all the way back to the fuel pump.
Another note. If you do have an "EEC" system, it's vented through the charcoal canister and thus would use a "sealed" gas cap. The non EEC types use a "vented" gas cap.
