Old 10-11-2018, 01:06 AM   #1
tino0217
Hazards not working
Where do I start to get my 1971 C10 hazard lights working all the other lights turn signals brake lights reverse lights work?
tino0217 is offline   Reply With Quote
Old 10-11-2018, 10:14 AM   #2
S_Gibson
S_Gibson's Avatar
Re: Hazards not working
Perhaps the flasher?
Stupidity was meant to be painful!
S_Gibson is offline   Reply With Quote
Old 10-24-2018, 12:55 AM   #3
tino0217
When i turn on the hazards on turn signal don't work. I haven't tried anything yet but wondering if they need to be bypassed. Any idea's where i should start? All other lights work.
Old 10-24-2018, 06:58 AM   #4
AASmedic
AASmedic's Avatar
Your flasher is definitely the problem. Replace it and everything should work just as designed.
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
Old 12-05-2018, 05:41 AM   #5
tino0217
Ouch.....im a newbie
Old 12-05-2018, 05:13 PM   #6
El Dorado Jim
like others have said, replace the flasher, there is one just for the hazards
El Dorado Jim is offline   Reply With Quote
Old 12-08-2018, 04:10 AM   #7
tino0217
I replace the flashers that hazards work but my reverse lights are not working does that come from that same flasher as well as the horn
Old 12-08-2018, 05:38 AM   #8
psuedopimp
psuedopimp's Avatar
Did your horn work before you replaced the flasher?
psuedopimp is offline   Reply With Quote
Old 12-08-2018, 01:26 PM   #9
AASmedic
AASmedic's Avatar
Your reverse lights work from a switch on the steering column. The flashers have nothing to do with you reverse lights or your horn. If you are having new issues after replacing a flasher then you have bigger problems than just a flasher not working. Do the hazards work after replacing the flasher?
Copyright ©2000 - 2019, vBulletin Solutions Inc.
