Old 11-29-2018, 01:29 AM   #26
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Build front suspension before or after mounting the engine?
Always figured 1 coil equals 2 inches
2 coils 4 inches.
If your only going 4 in the rear I would not cut a coil with your current 2.5 spindle.
Or... clip a coil and go down 6 out back. 👀👀
Old 11-29-2018, 09:15 AM   #27
Grumpy old man
Grumpy old man's Avatar
2 coils 4 inches.
This is what happened to me , the original plan was to just go spindles and 4" out back and I bought the 4" rear springs that Larry (GR8-68 ) changed out from his build to go to 6" Then after seeing the stance on his I had to switch gears again and go farther with my drop to match where he ended up . It's a never ending game of constant changes and more parts to get where you want to be .
Larry if you read this you cost me a bucket full of money !
pic is GR8-68's truck
Old 12-05-2018, 02:32 AM   #28
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
2 coils 4 inches.
Or... clip a coil and go down 6 out back. ����
I had the false impression a 1" (aka 2") drop coil didn't drop a truck any further than a 2.5" drop spindle already would.
If the stock height coils work toward my 4" & 2.5" goal then I'm good to use them. Hopefully I won't be disappointed I didn't drop it further The plan is for an originalISH build.
Tony
71 C10 Custom Deluxe, SWB, fleet, 402/400TH, A/C...Resource intensive......And (*^(*^ leaf springs. Speak of, looking for OEM rear sport bumper brackets for this ride. They're unlike those more common, even the outer brackets are different.
72 Cheyenne Super, LWB, fleet, C20, 402/400TH, A/C. Driver and tinker truck
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-05-2018, 07:15 AM   #29
Grumpy old man
I'll let you know how mine sits later today , providing parts arrive (no mail delivery here today ) Dropped in the engine and bell housing , Cut 1 coil off stock springs and using 2 1/2 drop spindles with new Moog ball joints . My other 67 short bed frame is only getting the front springs cut 1 coil and I'll be taking the 4" rear springs off this frame to use on the other frame and changing them to 5 " with a 1 inch block on this frame . should be interesting to see the difference between them side by side .
Old 12-05-2018, 06:09 PM   #30
71CHEVYSHORTBED402
Nice Grumps. Looks like energy suspension for your sway bar. I'm using the same, and their mount for a 400TH. What's your drive train?
Tony
Old 12-05-2018, 06:18 PM   #31
Grumpy old man
'71 truck 350 4 bolt to a stock 67 bell housing to a Muncie M22 Rock crusher to a custom drive shaft to a stock 12 bolt 3.73 factory posi to 29 x 15.5 x 15 Mt tires on the rear . I'm building this truck the way we would have done it in the early 70's .
Old 12-05-2018, 07:34 PM   #32
71CHEVYSHORTBED402
That's going to be a fun truck.
Tony
Old 12-07-2018, 12:58 AM   #33
KQQL IT
At the body shop.
KQQL IT's Avatar
I'm new to the 67-72 side of these trucks, been a squarebody guy for 20+ years.
I've always clipped 2 coils and flipped the back. Always sat right by my standards, looks and sits like a 4-6 drop.
That's where I came by the 1 coil is 2" theory.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
