Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-19-2018, 10:49 PM   #1
dave`12
dave`12's Avatar
Alternator draining battery?
I just completed a change over (long thread here) from external to internal regulated alternator. Well, I got sick right after, and didn't start the truck for several weeks. Dead battery when I tried.
I checked with a test light, and I have a battery drain that goes away (light goes out) when I unplug the 2 pin from the alternator. It's a 12si alternator.
Alternator definitely charging, and the ammeter in the dash is working properly. But I must have screwed something up, or got unlucky and got an alternator with a bad diode? Past history, I'm leaning towards "I screwed something up."
Does anyone know what likely is going on?
Thanx.
dave`12 is offline   Reply With Quote
Old 06-20-2018, 01:57 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Alternator draining battery?
Check the 1 and 2 pin wires to be sure they aren't reversed. IF the key is off the 1 pin wire will not have voltage, and when it is turned on,the wire should have 12 volts. The 2 pin wire should be hot all the time.l If they are correct then the alternator diodes could be shorted to ground and will drain the battery over time.
Sometimes the engine will continue to run with the key off when the two wires are switched.
I'll check one of my SI alternators and see what readings I get on the no. 2 connection between it and ground and then reverse the leads on the meter and see if I get a reading to see if it's flowing both ways.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-21-2018, 11:59 AM   #3
dave`12
dave`12's Avatar
Test light tells me I have a drain.
First I did a diode test from a utube video. battery disconnected.
.810 with + on case and - on btty post
ol with - on the case and + on the bty post
So, I'm thinking the diodes are good?
The other tests:
battery 12.45v
Key off
Btty post of alt 12.45v
post 1 12.45
post 2 .7mv
Key on
Btty ost of alt 12.45
post 1 12.40
post 2 11.98
Just for fun, tried it with the engine on:
btty 14.4
btty post of alt 14.9
post 1 14.9
post 2 14.5
I also removed the - lead of the btty with the engine running and the engine did not die.
So does this mean that I simply got these 2 wires reversed (I hope)?
Oh, the engine has been turned on some 15 times since the conversion and has always shut right off with the key.
thanx again
Old 06-21-2018, 12:29 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I'm working a similar post where the engine is running after key off but no battery drain. I think you might have the same type problem but a different diode in the alternator is shorted through and allowing battery current to go to ground. The other on is a diode that allows current to go back to the ignition switch.
The test you did on the charging post to ground on the alternator body is correct but you may have a bad diode on the small wire terminals 1 or 2.
My alternators tested 40 to 50 ohms both ways on the no 1 terminal and showed varying resistance on the no. 2 around 18 ohms one way and higher the other. This is with all wires to the alternator disconnected. If you get zero either way on the no. 2 you've probably got a bad diode. It can still charge at 14.5 volts but will drain the battery over time. Did you test for drain between the negative cable and the battery post? You should not get over 3 milliamps. That's .003. Make sure you have all the lights off and the key and no other draws on the system.
VetteVet
Old 06-21-2018, 01:11 PM   #5
dave`12
dave`12's Avatar
I was hoping I had the 2 wires wrong to the posts and that I could could swap them and put this behind me. Guess not? Anyway:
I don't have time to unhook alternator, I have to leave for work now.
Here is a quick test of how I THINK I should test amps and the draw. If correct, I have a big draw. Please look at the picture as I'm not sure how to test for amps.
The draw goes to 0 when I unhook the 1 and 2 post connector to the alternator, so the problem must be the alternator or the wires to it.
I will try the ohm test tomorrow morning.
thanx
Old 06-21-2018, 06:54 PM   #6
dmjlambert
dmjlambert's Avatar
Originally Posted by dave`12 View Post
...The draw goes to 0 when I unhook the 1 and 2 post connector to the alternator, ...
Do you mean when you unplug the 2-pin plastic connector, or when you unscrew the terminal lug nut on the back of the alternator, when the draw goes to 0?
Are you testing for draw with the key off?
Does terminal 2 of the 2-pin plastic connector lead to the existing junction (solder by factory) by the headlight?
Does terminal 1 of the 2-pin plastic connector lead to the brown wire that goes to the cab firewall connector?
If you think things are wired OK, I believe most car parts stores will test the alternator for you.
Old 06-22-2018, 02:59 PM   #7
dave`12
dave`12's Avatar
Yes, the 2 pin, I have not taken off the btty post (terminal lug?)
on and off, numbers for both are above.
I was pretty careful putting it in, and it's all taped up now. If worst comes to worst, I will untape and check.
Before taking it off, I was thinking about swapping the 2 pin wires and doing the btty test drain. That won't hurt anything will it?
thanx
Old 06-22-2018, 08:00 PM   #8
dmjlambert
dmjlambert's Avatar
I'm not clear about what is going on. The picture you show of the multimeter shows it set to the 200 mA range and displaying 2.9, so that is a trivial 2.9 mA. That does not seem consistent with conditions that would cause a test light glowing when hooked up in place of the multimeter. To hook up the multimeter or test light, are you disconnecting a terminal of the battery and connecting the leads to the loose battery cable and the battery post? With key off? Then while monitoring with the light or multimeter that is when you disconnect the plastic terminal from the alternator and notice the change? If it were me I would just unwrap and double check the wiring visually, because it would be rolling around in the back of my mind driving me crazy to not see it. Then I would take the alternator up to the parts store and have them check it.
Old 06-28-2018, 07:57 PM   #9
dave`12
dave`12's Avatar
Ok, finally got to this, been out of town and working a lot. Anyway, I reversed the wires going into the alternator 2 pin.
Started the engine. Seems to charge normally. Test light no longer lights up when I connect it from the neg battery cable (removed) and the neg btty post.
This hopefully means I no longer have a drain!
It's 12.84 now. Letting it sit overnight with the battery hooked up and gonna check the voltage in the morning. Fingers crossed that I was just stupid and somehow managed to get the wires backwards despite double and triple checking.
thanx
Old 06-29-2018, 05:12 PM   #10
dave`12
dave`12's Avatar
24 hours and it's at 12.5 volts. Hoping that switching the wires fixed her.
Old 08-05-2018, 12:40 PM   #11
Gregski
Gregski's Avatar
same problem as OP
Gregski is offline   Reply With Quote
Old 08-05-2018, 12:50 PM   #12
Gregski
Gregski's Avatar
My 1 pin has voltage with the key turned off. This is on my '71 by the way which I am running an internally regulated alternator circra 3rd gen now in a one wire configuration. I don't think I should just swap the wires on the pins, I think I should find a switched power source maybe? I did a similar one wire conversion on my '74 and that works great! so sometimes I know what I'm doing, lol
This 2 pin is correct it is hot all the time.
Old 08-06-2018, 01:03 AM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Clarify this for me.
You have a 71 with an internally regulated alternator. It's now a one-wire alternator. Are you saying the wire that goes to no.1 pin is hot with the key on or off? Or have you installed a 3 wire internally regulated alternator and the wire is hot with the key on or off.?
If it's a 3 wire then you will have to find out why the pin 1 wire is hot with the key off. The wire that goes to the no.1 pin comes from the key switch accessory terminal where it is joined with a brown 12 gauge accessory terminal wire that feeds the fuse panel.
the no1 pin wire is a 20 gauge resistance wire equivalent to 10 ohms, which equals the alternator charging light on the light dashes. Gauge dashes don't have the light but they have the wire. it powers up the alternator when the key is turned on to ignition or to accessory.
I seem to remember a thread where a member had a feedback from the fuse panel to the accessory wire terminal which sent voltage to the alternator when the key was off. I think it was in the key switch harness plug and there was a short between a hot wire and the accessory wire.
When this wire gets to the cab side of the firewall plug it exits the engine side as a 16 gauge brown wire that use to run to the external voltage regulator, This is the same wire that goes to the no. 1 pin on the alternator.
If you can't find the source of the live voltage when the key is off then there are a couple of ways to work around it. It would be better to find the short but if you can't then we'll look at them.
VetteVet
Old 08-06-2018, 11:28 AM   #14
Gregski
Gregski's Avatar
Thank you so much for taking the time to respond and help, I will try to answer your questions one at a time, maybe together we can figure this out and help others in the future.
Clarify this for me. You have a 71 with an internally regulated alternator. It's now a one-wire alternator.
No, I have a '71 cab with a modern internally regulated alternator which I have converted to a one wire now.
Correct, I have an internally regulated alternator that I have converted to a one wire.
Exactly.
The wire that goes to the no.1 pin comes from the key switch accessory terminal where it is joined with a brown 12 gauge accessory terminal wire that feeds the fuse panel. The no.1 pin wire is a 20 gauge resistance wire equivalent to 10 ohms, which equals the alternator charging light on the light dashes. Gauge dashes don't have the light but they have the wire. it powers up the alternator when the key is turned on to ignition or to accessory.
That seems right, I followed it from the alternator through the firewall and up to the key switch.
I will go on and troubleshoot that section then, thank you so much.
Yes, correct, spot on, I followed exactly precisely some diagrams on this forum how to convert a '71 harness to a one wire setup. And the part in the engine bay I believe I done did right.
Yes sir, I wouldn't doubt it if my ignition key switch had a short in it. Though I took it apart and examined it once already.
Old 08-06-2018, 11:59 AM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You can try a simple test. Unplug the brown wire 12 gauge, at the fuse panel and the pink wire at the fuse panel and test for feedback voltage to the key by measuring the No. 1 pin wire with the key off for 12 volts. If you don't get it then your problem is downstream of the key switch.
The pink wire also has other connections that could provide feedback but the fuse panel is the main one. The orange wire on the fuse panel is hot all the time for the parking lights the stop lights and dome light, but the ignition should be hot
I have an appointment now so I will check back later. VV
VetteVet
Old 08-06-2018, 12:25 PM   #16
Gregski
Gregski's Avatar
OK, just to be clear in order to do this I had to unbolt the fuse panel from the firewall and unplug both the thick pink wire and the thick brown wire from the back side of the fuse panel, by pulling off these 90* elbow looking connectors? Just for the record the pink wire Y's into the back of the fuse panel where I unplugged it and the other end of the Y goes to the bulk head connector on the firewall.
... and test for feedback voltage to the key by measuring the No. 1 pin wire with the key off for 12 volts. If you don't get it then your problem is downstream of the key switch.
OK, I did and I still have juice at No. 1, still getting voltage there, but... but... but... I don't believe my key is in the OFF position, I think this ignition switch is so jacked that it is allowing me to pull the key out whilst it is turned all the way to the left (counter clockwise) to what would be the Auxiliary position. So I turned the key one click over to the right, where I imagine the OFF position would be, and whalla no voltage at the No. 1 Pin. Could this be it?
[I]The pink wire also has other connections that could provide feedback but the fuse panel is the main one. The orange wire on the fuse panel is hot all the time for the parking lights the stop lights and dome light, but the ignition should be hot
Did you mean to say "... but the ignition should not be hot" sorry for troubleshooting your troubleshooting, ha ha
Old 08-06-2018, 03:58 PM   #17
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Well I think you may have found the problem with the key switch. What I meant to say was that the pink wire should be hot only when the key was on, but I was being rushed to leave so I missed the last part . good catch on your part, this could have been confusing.
What's your plan? New key switch? or can you fix the old one?
I'm curious what you did to make the alternator into a one-wire from a three wire because the one-wire uses a different regulator.
VetteVet
