#26 |
Re: Zane's 71
Rebuild the vent windows. Not a tough project. Made much easier with all the threads showing how to do it. Used seals from Classic Parts. They fit like a dream. Setting the rivets is not hard as long as you get a good solid surface on the head of the rivet.
Zane's 71 Build |
#27 |
Re: Zane's 71
Brakes, we have brakes. Purchased master cylinder and front hoses from Classic parts. They ship quick!
Bleeding went quick with a stop for homework. Went through all the wiring under the dash. Lots of DIY tap into hot wire for power spots. Quick to fix. However, I did come across a plug with no home. Must be part of HVAC; one wire connects to the switch on the diverter box. Any idea to what this is supposed to connect?
Zane's 71 Build Last edited by rcazwillis; 11-26-2018 at 11:38 PM. |
#28 |
Brian
![]() Join Date: Apr 2014
Re: Zane's 71
Really moving along nicely guys! I like Zanes wheel choice also. Kudos for such an in depth project/ mechanical education with the young man... He will never forget it.
#29 |
Re: Zane's 71
Truck is scheduled to go to paint on Jan 5. Painter is someone I have used before. He will have it back to me before end of January. He is going to paint inside and out of fenders, hood, cowel, cab interior, jams, and doors.
Truck now runs and moves on it's own. Had the distributor 180 out of time. Once I fixed that, it started right up. Had one rocker that needed adjustment. Still need to put a reservoir on for the power steering.
Zane's 71 Build |
#30 | |
Re: Zane's 71
Zane's 71 Build |
#31 |
Re: Zane's 71
Truck went to painter on Saturday. Saturday afternoon, I purchased a vehicle for my older son. His current vehicle is a 2005 Mustang. Sunday, had the car detailed preparing to sale it. Oh, the clear coat is pealing off the car! Had it painted 18 months ago by the painter I dropped the truck off to Saturday. Went to see him today to discuss our future business relations...
On the way, I noticed the diff was making an awful noise. More repairs. He saw the paint and said "I can respray it next week. I was using a brand of paint that has done that on a number of vehicles. I no longer use it and the truck will not have that issue." Perfect answer. In addition, he had the truck bed 3/4 of the way stripped. With that said, I proposed a trade. He gets the car and gives me some cash. He jumped all over the deal. I was honest about the diff noise. In the end, I don't have to fix the diff or put any effort into selling the car and realized about what I thought I could sell it for prior to diff noise. Now, just have to make sure the paint comes out as expected.
Zane's 71 Build |
#32 |
Re: Zane's 71
Truck is back from paint. A few areas are going to need his attention, but he agreed before we settled. Pushed him to get it done quickly, if you can call 4 weeks quick. Zane is happy and that is what counts!
We started putting it back together Saturday and Sunday. About 11 hours of work between the two days. Dash looks good. Doors are coming together. Should be done with the interior and deep into the exterior by end of this coming weekend. He turns 16 on 3/5/19. Has to be done by then!
Zane's 71 Build |
#33 |
Re: Zane's 71
Lot of progress this weekend. Big items were carpet, seat, back glass, windshield, speaker panels. Carpet was wriggled, but after one day was laying flatter. Already looking a lot better.
Back glass was easy. No issue getting trim in the gasket or installing the window. The trim for the front glass took a long minute to get into the gasket. Between Zane and I, the trim finally set into place. After reading every post, watching every YouTube video, and worrying about it, the front glass went in without any real issue. Lubrication, lot's of lubrication makes a difference. Making sure the outside lip is in the proper place and pushing the window down while working the inside lip helps too. The speaker panels are poorly formed. Not a big issue, but you would think they would fit. Trimmed quite a bit of material off the back side. The panels came with screws, but used 3M 2-sided tape to install to avoid more holes. Had to move the hi/lo beam switch as it was under the speaker panel. Easy change, but not expected.
Zane's 71 Build |
#34 |
D.U.F. Member
![]() Join Date: Nov 2001
Re: Zane's 71
Awesome read along. Great project and way to go Zane.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III T56 six speed swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#35 |
Re: Zane's 71
nice truck, so cool that it was your dad's and now your son's!! great project for you and your son, I did builds with both my sons when they were teenagers and they still have their trucks today...
#36 |
Re: Zane's 71
Cool. He claims he will drive it forever. I hope not, cause I want it when he moves on...
Zane's 71 Build |
#37 |
Re: Zane's 71
Busy weekend. Zane purchased a new grill surround with some money he had saved. Looks great, but quality is no where close to an original. Closer to aluminum foil than the factory material. Oh well, looks good.
Put some molding back on. Have three pieces still to polish and paint. One cab corner piece is crooked, not sure why. Ground issue with the bed. No tail lights. Will run some grounds to bed, does not appear to be any connecting the bed to the frame.
Zane's 71 Build |
#38 |
Re: Zane's 71
Door seals suck! Glued in a new set, doors were no where close to closing. After numerous adjustments, doors were so far out of alignment that we took the seals back out. Not sure what to do next. May try the Honda Civic ones.
Zane's 71 Build |
#39 |
Re: Zane's 71
GMC Pauls, they have press on door rubbers,easy to put on and no messy glue, nicer to work with if you have to take them off to make door adjustments.
#40 |
Re: Zane's 71
I went to the local pick and pull, got door seals from 91-99 dodge Dakota, press on and only about 3" longer than the 67-72 door opening, already pre shrunk from the dodge, cost me $18 for two sets, got second set just in case they were not long enough, wound up having a set for my other truck, so bonus
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
#41 |
Re: Zane's 71
Zane had the day off school today. He and a buddy went to the pick and pull. He found a decent set of seals off a 2007 Honda Civic. They fit perfect. Length is perfect. Press on. Door shuts perfect. Needs a little adjustment on top, but very pleased. Will post a picture of the glue on vs HC seals.
Zane's 71 Build |
#42 | |
Re: Zane's 71
#43 | |
Re: Zane's 71
