06-20-2015, 09:21 PM | #1 |
I'm not sure what's wrong. Help!
Hello everyone! I have a 1972 C10 with a 350 and it has electronic ignition. So here's the problem, sometimes when I go and try to start my truck, I turn the key, and it just clicks once. So I turn the key back to the normal position, and then try again, and sometimes it clicks, sometimes it turns on. Or sometimes it even turns on first try. And rarely it takes me 5 or 6 key turns to get it to finally crank. Does anyone have any idea what that could be? I tested the battery voltage out and it's at 12.7 so I don't think that's a problem. I was maybe thinking the starter, but I wasn't 100% sure. Thanks everyone!!
06-20-2015, 09:32 PM | #2 |
Re: I'm not sure what's wrong. Help!
Could be the solenoid on the starter. That would be my guess.
06-20-2015, 09:34 PM | #3 |
70+ ( Old Skool Club )
First thing I'd check is the battery connections and make sure they are clean and tight. Then I'd check the connections to the starter for the same reasons. Your key tumbler may be somewhat worn out. If all that is good I'd pull the starter and get it checked out.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-20-2015, 09:49 PM | #4 |
blood type; Retumbo
Contacts and copper disc in starter solenoid get pitted and cause this symptom
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
06-21-2015, 10:48 AM | #5 |
i'd check the neutral safty switch out for lossness or not aligned properly due to slack in the column
06-21-2015, 04:05 PM | #6 |
Awesome I'm going to check out all of this. Thank you all for the help!
06-21-2015, 04:50 PM | #7 |
I would check ground at battery and work my way back... If the headlights shine and the radio plays its a ground issue. Clean the connections and done.
