06-20-2015, 11:51 PM | #1 |
Rear Panel Upper cab moldings - What's the difference between the two moldings?
71 Chevy 1/2 ton.
Talking to one of "our" more knowledgeable posters, we're both a bit stumped on what the differences are between the two rear cab moldings "paint separators", being they're two different GM part numbers. The only difference I see is the RH reaches about 1/4" closer to the front. At first I thought that's just how they ended up, but now I'm not sure why that would be, considering the bend should be the same on both sides of the cab. Other than that, I don't see a difference between them. Seems one would work for either side. Anyway, that's a question. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-20-2015 at 11:56 PM. |
06-21-2015, 11:18 AM | #2 |
Re: Rear Panel Upper cab moldings - What's the difference between the two moldings?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-21-2015, 02:48 PM | #3 |
What are the part numbers?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
06-21-2015, 09:12 PM | #4 |
The top of the trim is more of a rounded 90 degree angle the bottom of the trim has a slightly beveled angle to it sloping towards the cab as it goes down rather than straight in like the top. It's a subtle difference.
Paul Jr. @ GMCPauls |
