Old 01-09-2018, 07:49 AM   #1
Beatrice
Beatrice's Avatar
raised bed floor question bagged truck
i'm getting to the point of mounting my new fleetside bed on my 63'. this is my first c10 build so i was wondering from anyone thats raised their wood bed floor how many cross sills are you using? my truck is c-notched and bagged so i wasn't sure if i could just use the front two and just the rear sill.
I looked around on here but most pictures are down and didn't see much info on my specific question
Beatrice is offline   Reply With Quote
Old 01-09-2018, 08:11 AM   #2
PGSigns
PGSigns's Avatar
Re: raised bed floor question bagged truck
How much do you plan to raise it? When I did my 65 it had a c-notch and when aired out it just missed hitting the bed floor by a hair. So I added a pair of traction bar snubbers for stops and used the floor as it was.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-09-2018, 08:15 AM   #3
Beatrice
Beatrice's Avatar
notch is 8'' so i'll have to raise quite a bit. need to get cross sills ordered to get bed bolted together and on before I get to that point. I just didn't want to order all 5 cross sills if I only need to use 3 total
Old 01-09-2018, 10:23 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Raising the bed that high, it might be better to build a frame structure to mount to the cross sills/inner bed sides. That's what I did for my friend's bed when he did a step notch like yours similar to this one.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-09-2018, 10:29 AM   #5
Beatrice
Beatrice's Avatar
did you mock the bed up on the oem sills to get the bed placed in the right spot first. So it sits even and with all body lines lined up with cab then just build up off that?
I was thinking use the oem front two sill and the rear sill of course. then just do like you did and built a 1x1 tube frame as high as it needed to be but keep the stock sills to make sure it sits as factory and would give some lower structure. unless i'm missing something. the truck was apart when I bought it and never put one together
Old 01-09-2018, 11:04 AM   #6
vin63
vin63's Avatar
Yes, we had to mock up the bed on the chassis a few dozen times while fabricating the bed floor structure. We mounted the bed cross sills directly to the bed (I noted ended up raising the bed floor 1 inch, which I raised my bed floor). I cut several .75 inch thick aluminum blocks and attached them to the chassis pedestals to replace the thickness of the bed wood ...if that makes sense.
Old 01-09-2018, 11:10 AM   #7
Beatrice
Beatrice's Avatar
yes perfect. that's what I was hoping to do. my plan was to use the front two sills and rear. mount those to frame and then put .75 square or round stock for spacers (where wood was) then once that's all squared to the cab and good to go I can then start welding my 1''x1'' square like your picture. Only difference is I'm doing a tilt bed floor between the wheel wells so mine top will be setup different. i'm going to put my spacers above the cross sills so I don't have to change the spacing on the inner bedsides itself.
thanks for your help I was hoping it would work out like that.
Old 01-09-2018, 11:51 AM   #8
clarsen
As another option, this is what i came up with.
Installed 2x4 tubing between the frame and sills (you would need 8") then welded angle around the perimeter of the bed. I built up the area at the tailgate with a few pieces of angle and flat bar
clarsen is offline   Reply With Quote
Old 01-09-2018, 01:07 PM   #9
joe dirt
joe dirt's Avatar
I built mine attached to the bed sides and bolted to the frame, also built in a hinged center section for access to the bags etc..
1961 c10 longbed
joe dirt is offline   Reply With Quote
Old 01-09-2018, 01:10 PM   #10
Beatrice
Beatrice's Avatar
that's pretty close to what I was looking at doing. do you have any closer pics of the hinges you used and how you did them?
Old 01-09-2018, 01:31 PM   #11
joe dirt
joe dirt's Avatar
got the idea from coulters build, I couldn't find any hinges that would work for my application, so just made some
1961 c10 longbed
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
