Old 01-09-2018, 01:35 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
Np205 rattling shifter fix???
Hey guys my 72 jimmy has developed a nasty rattle in the shifter for the transfer case and is wicked sloppy where can I get parts to rebuild the shifter linkage??
gmc1971harwich is offline   Reply With Quote
Old 01-09-2018, 08:04 PM   #2
orangek5
orangek5's Avatar
Re: Np205 rattling shifter fix???
Go Where I Always start.
I typed in np205 in Amazon and there are several parts listed.
https://www.amazon.com/s/ref=nb_sb_s...=3MQ1V1OIGESRR
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 01-10-2018, 03:04 AM   #3
Spf79
Spf79's Avatar
I had an old 3/4 ton square body that had a high pitch metal ringing/rattle that came from that 205 shifter set up. I took it apart and reassembled with some different types of washers... I can't remember how I associated the washers, but I found the key was to tighten it with a nylon washer so that it had some squish. The nylon washer allowed me to keep it tight but be able to still shift it. I think there is a bushing that the shifter arm rides on where it bolts to the transmission adapter. Mine was long gone, this was maybe 10 years ago and I could not find a replacement. I never got it to work the way I wanted, it shifted better... but was still hard to get into low range since it would bind. The rattle was gone though.
I went with a twin stick set up this time around. I bought the shafts and adjustable detents to go along with the shifter. I am very happy. I like the look and it shifts really clean and crisp. Unfortunately you have to take the transfer case out and pull it apart to switch out the selector shafts. (Sad face)
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 01-10-2018, 03:20 AM   #4
Spf79
Spf79's Avatar
This thread is helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=331598
Old 01-10-2018, 10:52 AM   #5
simicrintz
A lot of the Jeepster guys do the twin stick mod as well and seem to be real happy with it.
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 01-10-2018, 03:30 PM   #6
cleszkie
cleszkie's Avatar
Not trying to insult your intelligence, but make sure you have the NP205 in 2Hi, and not 4Hi. These two are right next to each other in the shift pattern and easy to confuse. If you are running in 4Hi by accident, the front driveshaft will be spinning and can cause vibration and noise in the case. I did this once and could not figure out where all the extra noise was coming from until I double checked the shifter and found I was in 4Hi instead of 2Hi.
cleszkie is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
