Old 05-22-2019, 03:46 PM   #1
mikebGMC70
Driveshaft movement
I have a 70 c20 with a manual 4 speed. Having my 2 pieces drive shaft balanced and mentioned to my driveline shop Iím bagging the truck and they mentioned the driveshafts might push in on the transmission or rear end to hard when going up or down with the bags. Any thoughts on this? Thanks
mikebGMC70 is offline   Reply With Quote
Old 05-22-2019, 06:09 PM   #2
Overdriven
Re: Driveshaft movement
When you lower a trailing arm truck the rear axle moves forward pushing the driveshaft forward. The slip yoke going into the transmission has some wiggle room there and the stock carrier bearing is rubber mounted to account for some of this movement when the suspension is compressed at stock ride height. Lowering with airbags obviously moves the driveshaft more than hitting bumps in the road at stock ride height. What is the limit? I don’t know.
For those who want to never worry about this, the fix is a billet carrier bearing and adding a slip yoke (telescoping shaft) to the driveshaft after the carrier bearing. The billet carrier bearing has no rubber mount to degrade and as such doesn’t move. To account for the movement a slip yoke is added between the carrier bearing and rear axle.
Overdriven is offline   Reply With Quote
Old 05-22-2019, 06:57 PM   #3
mikebGMC70
My carrier bearing has a slip yoke style. Would this work with the airbag setup?
Old 05-22-2019, 08:32 PM   #4
mongocanfly
You need to get the truck at ride height...then determine what the driveshaft needs....be mindful of changing pinion angles when lowering...trailing arms tend to roll the diff yoke down as the truck drops..
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 05-23-2019, 03:09 AM   #5
EVRLET
Active Member
EVRLET's Avatar
This is what a bagged truck 2 piece driveshaft looks like.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
