Old 06-02-2019, 11:27 PM   #1
Bushman66
What sealant on 292 Head bolts?
Got the head off, and the bolts look great, I did see that there was remnants of some kind of sealing compound on the threads. I have a thread cleaning chaser tap coming, didn't want to use my threading taps to clean up the threads in the block. I read that the torque rating is 90-95 Ft/lbs,tightened in a spiral pattern from center out. I'll probably torque in stages, 30/60/95...I've had good luck using that method through the years.
My question...what type of sealant do you use on the bolts? Plain old black RTV silicone? Assuming just a small dab on the threads to keep water from seeping?
Thanks!
Bushman66 is offline   Reply With Quote
Old 06-03-2019, 11:39 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: What sealant on 292 Head bolts?
I used liquid Teflon thread sealant (like the tape stuff but in liquid form). I have used RTV before but it can be a pain to get off down the road.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-03-2019, 04:55 PM   #3
68Gold/white
I have used RTV, but now use the teflon stuff, also. My engine builder said to...
I coat the entire threaded end of the bolt. No interest in having water in my oil...
68Gold/white is offline   Reply With Quote
Old 06-03-2019, 04:57 PM   #4
Bushman66
Thanks guys!
Old 06-03-2019, 06:59 PM   #5
cadillac_al
I have never tried the liquid teflon. I can't imagine anything being better than old Permatex #2. I don't change my ways very often. Maybe somebody here has tried both and can enlighten me lol.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Old 06-04-2019, 08:44 PM   #6
crazy longhorn
Fabricate till you "puke"
I have used form a gasket aviation, rtv, ect.....the last 3 builds that I did, were liquid teflon. No issues at all.....I am also old school, but the liquid teflon works longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-06-2019, 02:19 AM   #7
GRX
GRX's Avatar
Machined and built literally 100s of these inline six for fleet service back in the day. Some came back later with over 300k miles. Permatex #2 form-a-gasket always worked fine.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
