Old 06-12-2019, 01:43 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
Truck will not turn off
I have a 1979 K5 Blazer and today, after going to run some errands, the truck will not turn off with the key turned off and even removed. I have to pull the hot wire off of the distributor to shut off the engine and pull the negative battery cable to disable the electric fuel pump. I would assume its either the key lock cylinder or the ignition switch, but I figured I would consult y'all first before digging into anything.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-12-2019, 02:15 PM   #2
mongocanfly
Re: Truck will not turn off
that would be a place to start
Mongo...aka Greg
2013 GMC Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 06-12-2019, 02:37 PM   #3
Dead Parrot
Feedback from the Alt through the Alt light/field wire can cause run on. Normally fails open but you can check by pulling the 2 wire plug out of the alt.
Agree that most probable is ignition switch or the linkage from the key cylinder to the switch.
Dead Parrot is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
