Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-16-2009, 07:01 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Front side marker light problem
I'm working on getting all the lights on my 72 Jimmy working properly, and I'm doing pretty good, except for the front side marker lights. The driver side one works, but is dim. The pass side did not work at all, then after moving some wires around, it did work, then quit again. I can't find any problems with the wires, splices, etc.
The wiring diagrams all show the side marker lights having a brown positive lead, then a black ground wire, but that's not what I have. Mine is a brown wire and a blue wire. The blue wire ties in with the front parking/signal light. Interestingly enough, that is how the 73 and up trucks are wired. This is the same as the light wiring on my 71 C-10 also.
The only other problem so far is the turn signal circuit isn't working. The flashers worked, blinkers not so much. I've tried 3 different flashers. Two of those worked for sure on my C-10. Any thoughts or ideas appreciated.
Screws fall out all the time. The world is an imperfect place. Bender
Build your own adjustable track bar
71 Long Fleet C/10
72 Jimmy 4x4 (Junkyard Jimmy)
Bigass Farm Truck
HG's thread of miscellaneous stuff
hgs_notes is offline   Reply With Quote
Old 09-16-2009, 07:03 PM   #2
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: Front side marker light problem
Try spilcing in an additional ground at your side marker lights. See if that helps.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-16-2009, 07:39 PM   #3
bigbadchev72
People know me
bigbadchev72's Avatar
Dim lights are from a bad ground. I bet this is your problem.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-16-2009, 08:26 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I doubt it is a ground problem. Front side markers that are wired like this one are not grounded the traditional way. One wire goes to the parking light circuit, the other wire to the turn signal circuit... both are positive.
I would follow the brown wire (parking light side) till you find some damage or corrosion. Added resistance will kill the light output too.
As for your turn signals, do you have both front and rear lights hooked up and working?
Old 09-16-2009, 08:57 PM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
Longhorns right, you cant ground the front side markers. Well you can, but your just cutting the turn signal wire and using it as a ground. I swapped the hazard and blinker flashers around and got them to work.
Odd things keep coming though. With the headlights on, the tail lights all look good, driver side front marker is ok, passenger side front marker off, left turn signal will not work, right turn signal does.
Headlights off, all the blinkers and front side markers work, but the left side is slower than the right. I think I have bad connection in the left blinker tail light wire. I think there is a problem with the right front blinker wires too.
I'm getting there though. I think on the front blinkers, the blue wire is the positive and the brown acts as a ground for the side marker lights, then switches for when the parking lights are on. I THINK anyway.
71 Long Fleet C/10
Bigass Farm Truck
Old 09-16-2009, 09:48 PM   #6
fixit-p
fixit-p's Avatar
Here's a diagram.
The brown wire is positve with the lights on it flows through the side marker and taps into front park/turn light it flows to ground through the turn light filament of the front park/turn light. With the turn signal on that side of the front park/turn light now has power and does not allow the marker light to flow to ground thats why it flashes on the taillight circuit (just like when the alt dummy light has positive power on both sides it goes out). Check the grounds on both front park/turn lights including the bulbs and sockets.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-16-2009, 10:14 PM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
Originally Posted by fixit-p View Post
Here's a diagram.
Excellent! That diagram is much easier to follow and your explanation is spot on. I didn't have the parking lights mounted, which is why there was no ground for the side markers. I should be able to get all these babies working soon.
71 Long Fleet C/10
Bigass Farm Truck
Old 04-25-2011, 12:24 AM   #8
67-72trucks
Thanks for the diagram
67-72trucks is offline   Reply With Quote
Old 05-29-2019, 04:37 PM   #9
callonor
callonor's Avatar
This diagram is the best! Helped me with a few wires and re-wiring for LED's. Thanks so much!!
callonor is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
