Old 05-30-2019, 01:42 PM   #26
drew8mc
Re: For all you vacuum guage soothsayers
The more I think about this, the more I think I have some kind of vacuum leak. I can back off of the idle screw so it's not even touching the linkage, and it still idles at 800. The idle mixture screws have very little effect on anything, while being fully out of the transition slot. I've got to be sucking air in somewhere.
drew8mc is offline   Reply With Quote
Old 05-30-2019, 04:07 PM   #27
geezer#99
geezer#99's Avatar
Sucking in air!
You say primary is closed enough, what about the secondaries?
Old 05-30-2019, 04:51 PM   #28
drew8mc
Secondaries are closed now too. Once I figured out the slot was not overexposed I closed them back up.
Old 05-30-2019, 04:58 PM   #29
geezer#99
geezer#99's Avatar
How about the high idle screw?
Old 05-30-2019, 05:00 PM   #30
drew8mc
Could be engaged. But it does kick down from about 1500 with the choke on. I will check it when I get home.
Old 06-01-2019, 05:34 PM   #31
drew8mc
OK... I am partway there.
I had a long list of troubleshooting items to go through. I only got to item 2 before it looks like the popping sound is gone. I didn't hear any noise out of the valve train either.
Plug Wires!
I swapped my old set in and no more of that misfiring sound. No power drops or hesitations. These were brand new wires from DUI. I will probably pick up a different set in the future. These are old Summit wires from who knows when.
However, this thing after warm up is still idling at 1400. On startup it idles at 850. I'm thinking I might still have a vacuum leak that only shows up after it's warm. Is that possible? I checked the fast idle cam and screw and it is not engaged.
Old 06-01-2019, 06:23 PM   #32
geezer#99
geezer#99's Avatar
What gasket between carb and intake?
I’ve had gaskets hang up on the butterflies.
Old 06-01-2019, 07:02 PM   #33
drew8mc
I just checked the butterflies. They don't seem to be getting hung up on anything. I think the gasket was an open style... not the four hole style.
Old 06-02-2019, 12:14 AM   #34
Richard2112
Gasket leaks after warm-up is commonly intake manifold gasket. But it depends on manifold type, heads, etc.
Richard2112 is offline   Reply With Quote
Old 06-02-2019, 12:24 AM   #35
drew8mc
That's what I feared... but at least I know I don't have valve train issues anymore.
The intake was one of the only pieces to come from the old motor. The end of life of that motor involved losing the harmonic balancer and all pulleys. Limped it home with steam hissing out the front. I bet the intake got warped.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
