Old 05-26-2019, 11:36 PM   #1
JoeKan
JoeKan's Avatar
1970 Engine replacement
I have an opportunity to get a real nice looking 1970 Camper Special, it has some rust but not bad. The bad thing about this is the motor is shot. The owner said that it had a busted head gasket and let it sit for awhile before attempting to fix it and water had gotten into the piston.
I don't know very much about motor overhaul or replacement but can someone give me an idea of how big of a pain in the neck it would be to do this myself (with help) or how much it would cost if I paid someone to do this?
If I would be better off getting someone to do this, then who? "A" mechanic down the street?
I would hate to walk away from this because it's a good buy and I want to restore this old girl. Thanks for any help, Joe
JoeKan is offline   Reply With Quote
Old 05-26-2019, 11:44 PM   #2
truckster
truckster's Avatar
Re: 1970 Engine replacement
How handy are you with tools? Replacing an engine isn't rocket science, but it does take some basic mechanical knowledge and a good set of tools.
If I didn't build it or fix it, it's probably not mine.
truckster is online now   Reply With Quote
Old 05-27-2019, 12:03 AM   #3
JoeKan
JoeKan's Avatar
I think I have most of the tools, except something to pull the motor. I "think" I can do it. My problem would be that I don't have any time.
Old 05-27-2019, 01:17 PM   #4
truckster
truckster's Avatar
If you don't have time, my advice would be to farm it out and don't even start. It can take longer than you think, especially if it's the first time you've pulled and replaced an engine.
Old 05-27-2019, 02:46 PM   #5
JoeKan
JoeKan's Avatar
Would it need a compete overhaul based on the description from my first post?
Old 05-27-2019, 02:55 PM   #6
geezer#99
geezer#99's Avatar
If it sat for a long time with water on the pistons it’s likely an over bore won’t save the motor.
You’d need a replacement.
What are your engine expectations?
Stock or slightly modified.
Old 05-27-2019, 03:46 PM   #7
truckster
truckster's Avatar
I agree with geezer. Spending money on that block would be throwing money away. A crate engine is your best bet. The easiest and least expensive option is probably going to be a stock-ish type of crate engine from GMPP. Both Jegs and Summit carry them and often have good sales going on with free shipping.
Old 05-27-2019, 05:12 PM   #8
JoeKan
JoeKan's Avatar
Which one would be a good one? I don't want a hot rod, just something that will get me down the road with a camper on the back. It's a 4 speed. Thanks!
https://www.summitracing.com/search/...del/c20-pickup
Old 05-27-2019, 05:21 PM   #9
geezer#99
geezer#99's Avatar
Your linky no worky.
One like this.
All your stuff will bolt right up to it.
https://www.summitracing.com/int/par...make/chevrolet
Got your link working now.
Those are rebuilt motors.
Could be of dubious quality.
Old 05-27-2019, 07:43 PM   #10
truckster
truckster's Avatar
The price difference between new crate engines and rebuilt/remanufactured engines makes buying a new crate engine just so much smarter.
Old 05-27-2019, 09:50 PM   #11
JoeKan
JoeKan's Avatar
Thanks for fixing the link. I found out from the owner tonight that its a big block 4 barrel. I don't know why I was thinking small block. I'm planning on taking a look at it sometime this week. How much do you think it would cost to have the motor installed?
Old 06-02-2019, 09:23 PM   #12
Wrenchbender Ret
If its a big block & from what you posted about not much time or equipment I would pass on it. That is a big heavy engine. If you took it to a shop to have a new engine it would cost over$5,000. Then you would still have a lot of things to fix. Unless a guy can do his own work he is better off buying one that is already done. Then you can test drive it & check it out.
That's just my opinion.
George
Wrenchbender Ret is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
