Old 06-03-2019, 08:57 PM   #1
63longfleet
Clutch pivot bolt hole size
Do any of you motor gurus know what size bolt fits in the side of the block where the clutch pivot originally went. I'm trying to make a bracket to keep my plug wires away from the headers. Thanks in advance.
63longfleet is offline   Reply With Quote
Old 06-03-2019, 09:03 PM   #2
mongocanfly
Re: Clutch pivot bolt hole size
Assuming your talking smallblock, its ◊◊◊◊◊...correction::::1/2-13
Mongo...aka Greg
2013 GMC Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 06-03-2019, 09:11 PM   #3
63longfleet
Thanks Mongo
Old 06-04-2019, 06:54 PM   #4
crazy longhorn
Fabricate till you "puke"
If it screws into the block....it is 1/2 13 on the threads Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-04-2019, 08:34 PM   #5
mongocanfly
that's what I get for checking it in the dark with no light...I must've screwed a 3/8 bolt in wrong hole ill have to look in the daylight
Mongo...aka Greg
Old 06-04-2019, 08:49 PM   #6
crazy longhorn
Mongo, the other end , on the frame, is what you stated 3/8 16 thread We all get together to share ideas.....keep on truckin Bro, & share the info longhorn
Old 06-04-2019, 09:16 PM   #7
mongocanfly
naw. i went out there in the dark last night with a 3/8 bolt ( i think) and had to feel around on the block out in the back shed....the hole im talking about is in the block above the oil filter but its a 3/8 (again i think).either that or i picked up a 1/2" bolt in the dark.
ill have to look in the morning and see where i screwed it in....been a long time since ive messed with one mounted to the block
Mongo...aka Greg
Old 06-05-2019, 07:40 AM   #8
mongocanfly
You wuz right CL...1/2-13...that hole had a dirt dawber nest in it...amazingly the 3/8 bolt threaded it's thru the nest in there and wuz somewhat tight..till I cleaned the hole out
Mongo...aka Greg
Old 06-05-2019, 08:24 AM   #9
geezer#99
geezer#99's Avatar
One thing I’ve quickly learned on this forum is never doubt the wisdom of the great Mr. Shorthorn!
Old 06-05-2019, 07:58 PM   #10
crazy longhorn
I hate them dirt dawbers...Longhorn!
Old 06-05-2019, 08:04 PM   #11
crazy longhorn
Originally Posted by geezer#99 View Post
One thing Iíve quickly learned on this forum is never doubt the wisdom of the great Mr. Shorthorn!
Just dont ask me what I had for dinner last night.....I could not remember! Must be part timers longhorn
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
