Old 06-05-2019, 08:59 AM   #1
Minkota
Engine Dies when looking for Vacuum Leak
I was trying to adjust the Carter AFB Competition Series Carb and Timing last night and was having a little trouble getting it dialed in so I sprayed some carb cleaner around the carb to look for any vacuum leaks and whenever I sprayed it near the Electric Choke the engine would start to stumble and almost die.
Anyone run into this before?
Ever ask yourself why there is never enough Time and Money to do things right the first time, but always enough Time and Money the second time?
Minkota is offline   Reply With Quote
Old 06-05-2019, 09:23 AM   #2
geezer#99
geezer#99's Avatar
Re: Engine Dies when looking for Vacuum Leak
Yup!
I found the leak too!
Old 06-05-2019, 09:52 AM   #3
Minkota
Shouldn't the engine rev up when it is sprayed; it bogs and almost dies when I spray it...
The only thing I can think might be happening is the Carb Cleaner is coming out cold and making the Choke think the engine is colder than it is and applying the Choke.
Old 06-05-2019, 10:27 AM   #4
geezer#99
geezer#99's Avatar
Spray into the Venturi and see what happens.
Old 06-06-2019, 09:20 PM   #5
garyd1961
Electric chokes don't work that way. They don't care what temp the motor is. You have a leak around the choke somewhere.
garyd1961 is offline   Reply With Quote
Old 06-07-2019, 11:06 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Actually, the bi-metal coil inside the choke is expanded by electrical current heating the metal and expanding it. Spraying the choke with carb cleaner probably won't cool it enough to affect engine to die (as mentioned above) so it's more than likely a vacuum leak somewhere else.
You can double check that by removing the breather cover and actually looking at the choke to see if it closes.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
