Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-03-2017, 12:49 AM   #26
El Dorado Jim
Re: Another wiring question
Originally Posted by VetteVet View Post
Hello Jimmy- I didn't say anything about them because we were talking about the SI series alternators 10 SI and 12 SI. They already have the charging light or the resistance wire on the key switch for the 10 ohms resistance that they need. If You're going to install the newer CS style then you need more resistance but not necessarily the diode.
This thread tells about the conversions.
http://67-72chevytrucks.com/vboard/s...d.php?t=417872
thanks Vette, I have the diode, should I go ahead and install it? I am going to use the cs alternator on my 72
El Dorado Jim is offline   Reply With Quote
Old 04-03-2017, 08:18 AM   #27
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You will definitely need the resistor but the diode would prevent any feedback of current to the ignition system. In most cases it isn't needed because the resistor drops the current enough in the reverse direction to prevent the feedback. I wouldn't install it unless you get engine run on.
The brown wire will go to the L terminal and the S wire (voltage sensing) will go to the S terminal. Run it to the main junction of the alternator and battery.
If you have the battery charging gauge and you want it to work you'll have to run the alternator charging output wire to the main junction. Some guys run it to the battery positive terminal directly and then can't figure out why their gauge don't work.
I think I've posted this diagram before but Here it is.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-03-2017, 11:50 PM   #28
El Dorado Jim
thanks Vette
Old 05-18-2017, 09:03 AM   #29
SeanB242
SeanB242's Avatar
well . everything was going fine up until last weekend. lost marker, tail and brake lights and also dome light, headlights still work. after some tracing and looking back at the wiring diagram, i pulled the light switch out, and unhooked it. if i jump from the red wire into the the light plug to the other wires i can get them to work. if i plug the headlight switch back in then they dont work. i tried 2 different switches and even exchanged the one i bought and still the same. any ideas anyone? thanks.
SeanB242 is offline   Reply With Quote
Old 05-18-2017, 09:48 AM   #30
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You have lost power to the orange wire in the fuse panel. It feeds all the items you mentioned. Jumping the red wire on the headlight plug to the various lights just confirms that. Make sure your stop/ tail and dome light fuses are good and the connections are clean.VV
VetteVet
Old 05-18-2017, 09:19 PM   #31
SeanB242
SeanB242's Avatar
Gah! i knew it was something stupid. Just a suggestion, but when your son tells you he checked the fuses you should probably double check before tearing the dash apart. LOL Thanks as always Vette
Old 05-19-2017, 12:30 AM   #32
Jstock85
Dang! my front turn signals went out a while back and i just about tore the wires apart looking before i realized to just check the fuse. lucky me!
Jstock85 is offline   Reply With Quote
