Old 01-06-2019, 09:31 PM   #1
iceman4
door latch function
After two years driving and trying to adjust doors, rebuilt hinges, new door latch, new weather seal -soft seal, I could not get the door to close flush. I know the 2 positions of the latch was mentioned in posts on the subject, but I was confusing it, with door handle positions, locked and unlocked.
Just wanted to give a heads up (if someone else has a similar problem), if anyone has the striker positioned as far in as possible and still can't get the door to close flush, it is probably closing in the first latch position. Just need to move the striker out a bit to allow the latch to catch to the 2nd fully latched position.
See the pictures attached (sorry they are sideways) .The first two images are the incorrect striker and latch positions and improper door closing, the last two images are corrected.
iceman4 is offline   Reply With Quote
Old 01-07-2019, 05:05 AM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: door latch function
You are exactly right.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 01-07-2019, 03:42 PM   #3
Driver_WT
Driver_WT's Avatar
Thanks for the info. I will need it soon.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
