Old 06-19-2019, 06:23 PM   #1
siggyfreud
siggyfreud's Avatar
C-clips won't go back in?
Hey all,
Doing a Baer brake upgrade on the rear. With the axles out I decided to swap over to Moser axles, as I needed to machine either stock or a new set to fit the rotors.
New axles measured right, fit well, but I can't seem to get the C-Clips on. Outside the car they fit the axles fine. When I try and put them in, it's like they get stuck 1/4 of the way on the axle.
Last time I reinstalled c-clips on something else they went back in as easy as they came out with a couple fingers. I'm reticent to try and tap them back in.
Any advice? Should I buy new clips and try them?
siggyfreud is offline   Reply With Quote
Old 06-19-2019, 11:40 PM   #2
Captainfab
60-66 Nut
Re: C-clips won't go back in?
Have you tried having someone pushing in on the axles while you try and install the c-clips? Sometimes the axles hang up a little on the seals.
Old 06-20-2019, 01:13 AM   #3
siggyfreud
siggyfreud's Avatar
I have not. I'll see if I can wrangle someone over to do that, or even lightly tap on them with a hammer as I try and push the c-clip in.
