Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-13-2018, 06:50 PM   #1
CANUCIT
CANUCIT's Avatar
Back half , bed floor
Ok i have back halved it
Need some pics and experienced back halfers ideas on putting wood back in
Oh and wheel tub recommendations
Thx in advance
1962 chevy short and wide
2015 z71
1967 SS Chevelle
CANUCIT is offline   Reply With Quote
Old 03-13-2018, 10:15 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Back half , bed floor
I did a rear frame for my 66 last year, and ended up fabricating a multi piece subfloor from aluminum channel, which holds an aluminum bed skin.
Do you have any sections of frame which protrude above the floor height?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-13-2018, 11:54 PM   #3
CANUCIT
CANUCIT's Avatar
Yes and thinking of putting plywood down and covering it in aluminum
2015 z71
1967 SS Chevelle
Old 03-15-2018, 11:56 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This is the one I built last summer. Still need to finish the notch cover combo.
Old 03-15-2018, 12:36 PM   #5
tinydb84
tinydb84's Avatar
Here is my bed floor (well the frame at least)
David
Instagram: myfabguy
Old 03-15-2018, 03:35 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Outboard air bag / watts link . Loks of cool stuff going on in that picture^^^^
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-01-2018, 07:35 AM   #7
urmyboyblue
I welded tabs on my frame and used 2" x 2", 3/16" thick aluminum angle as cross members to mount my floor to. The tabs will have to vary in height so that the cross members end up at the same top height. Then I mounted my aluminum sheet floor to that. I plan on replacing the aluminum sheet with wood in the next year or so. Placed every 18" (I think), the floor is strong enough to support some load- I would not be concerned about standing on it once I get the wood in.
urmyboyblue is offline   Reply With Quote
Old 05-27-2018, 07:21 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
I will be doing similar . Tabs on the bed sides and the frame . Aluminum angle to mount the wheel tubes . I was told I needed a floor . That a truck with just a bed cover created some lift at the top end due to wind getting under and in the bed area.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Copyright ©2000 - 2019, vBulletin Solutions Inc.
