Old 11-16-2018, 09:18 PM   #2326
DransportGarage
DransportGarage's Avatar
Re: What did you do with your truck today, Part 3
Originally Posted by crossfire84 View Post
Get these, best money I've spent.amazon.$40.00
For those interested, here's the link: https://www.amazon.com/IWISS-Crimpin...s=crimper+kit\
That looks like a nice set! $28.88! I have a Panduit stripper that looks a lot like that one. Put a few cans of brake cleaner and starting fluid with it and you'll get free shipping!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-16-2018, 11:33 PM   #2327
MARTINSR
MARTINSR's Avatar
Being I will be out of town starting tomorrow I got out there and actually worked on the truck removing some rivets from heat shields that were attached to the frame. Straightened them out, and are ready to be powder coated.
I have a plan for some "work" on it while I am on my trip, we will see how that works out.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-17-2018, 01:40 AM   #2328
MiraclePieCo
MiraclePieCo's Avatar
Tough couple of days. I confronted the exhaust guy, told him I didn't like his installation at all. He was obviously unhappy, but agreed to redo it. Part of it is my fault for giving him free rein and not being more emphatic about how I wanted it.
Then I spent two days trying to fix a leak at that dreaded head plug that caused me so much grief awhile back. I tightened it - didn't fix the leak. I took it out (very hard to reach now) and re-sealed the threads with teflon tape instead of thread sealant; still seeping. Took it out yet again and replaced it with a different plug. It got dark before I had time to test it. Now there's so much danged antifreeze all over the whole underside of my truck I won't be able to tell if it's leaking or not. I don't even want to mention the worst case scenario here, that the head may have been cracked by removing the original plug.
Building these vehicles isn't always the romantic and fun process glamorized on TV shows.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-17-2018, 01:59 AM   #2329
vintovka
vintovka's Avatar
Ain't that the truth!!!!!
vintovka is offline   Reply With Quote
Old 11-17-2018, 10:37 AM   #2330
oldman3
oldman3's Avatar
Your right, and when it takes them 2 yrs to build a car, but 1 hour to show the work. Non car people think anyone can do it. Hope it's not the head...Jim
oldman3 is offline   Reply With Quote
Old 11-17-2018, 11:23 AM   #2331
vintovka
vintovka's Avatar
The "one hour restoration shows" seem to deliberately hide the true costs. They make all the labor seem free, sometimes mentioning how may hours it took in addition to parts cost. Shops around here are pushing $100/hr for comparison. Many are just hour long plugs for parts vendors. Even worse, if you subtract the all the four minute commercials the restoration is only 20 minutes long at most.
Old 11-17-2018, 11:24 AM   #2332
MARTINSR
MARTINSR's Avatar
I LOATH the "reality shows" of all kinds, OMG they are over dramatized!
But when something like that leaking plug happens, you COULDN'T BE over dramatized in real life that SUCKS! Hope it's easier than that. I know you don't want to hear this but there are some radiator stop leaks that work amazingly well that could put off the worse case for a while?
Brian
1948 Chevy pickup
Old 11-17-2018, 11:29 AM   #2333
MARTINSR
MARTINSR's Avatar
I did love Monster Garage when it first aired. It wasn't full of drama, it seemed pretty real. My youngest son was 5 years old as the first one aired and it was a great show for him and I to watch together. Great memories of watching it with my boy.
Brian
1948 Chevy pickup
Old 11-17-2018, 11:46 AM   #2334
vintovka
vintovka's Avatar
"OH NO!!!" followed by 8 -10 minutes of commercials 4 minutes of rehash and then "A RUSTED BOLT!!!! which they promptly just snap off and then on to something else. EVen "wheeler dealers" which is about the best of them just barely mentions the hours involved.
Not "chuffed".
Old 11-17-2018, 12:41 PM   #2335
DransportGarage
As it used to say in some of my textbooks: "The details are left as an exercise for the reader." ...or viewer, in this case. That's where all the cursing and busted knuckles come in!
Bob
Old 11-17-2018, 01:31 PM   #2336
dsraven
are you using a brass plug or a steel plug? if using steel maybe give brass a try,it is a little more conforming. also, if using teflon tape there are a few different tyupes. the type used for natural gas (around here anyway) is thicker. the code here says you can't use the regular teflon tape on a gas fitting,only the stuff rated for gas. anyway, you could also try some plumbers dope instead, it is a paste and contains teflon. my son is a plumber and thats all he will useon any npt fitting,least chance of leakage he says.
take out the old plug, inspect the threads on the plug to see if the threads in the head were forcing some of the threads on the plug to deform. if so then check the hole for anything that may look suspect in the threads
run a tap through the hole, keeping in mind that npt is a tapered thread so the deeper your tap runs into the hole the deepe the plug will also have to go into the hole in order to seal
select a new plug and check the threads on the plug to ensure they are all smooth and uniform
goop up the plug
screw it in and torque it up, not too much because pipe threads are tapered so the more you tighten it up the more it wants to make the hole bigger and if there is any chance of a small crack around the hole it will try to wedge open that crack.
lets hope the head is good and the threads just have a bad spot
Old 11-17-2018, 05:37 PM   #2337
svr
svr's Avatar
I found some purple locktite stuff that beats any thread sealer i have ever found, rarely use tape anymore on npt. Found it at a hydraulic store, they were useing it on high pressure hydraulic fittings, especially on stuff that would crack and break useing tape on tapered threads.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 11-17-2018, 09:07 PM   #2338
evilokc
this isn't truck related but I needed to vent. I have a 91 firebird. I bought it my accident from ebay two or three years ago. its a good running car and ive become really found of it. everything on the car id original..so 27 years old. the struts were originals.. hell everything but the tires which are the wrong tires for this car. im slowly going through and rebuilding the systems. right now its suspension. im having a hell of a time on the tierods. its so stupid. I ordered a kit and the outer tierods didn't fit. I ordered the correct outer and now it seems the inner and outer are both right hand thread. how does that even happen? how can you adjust them if they are both right hand thread?! dude this kind of crap is killing me. rant over. thanks for reading.
EDIT- I was able to install the outer tie rod but had to use the original inner for now. the click of death is gone so I guess that's worth the time it took me to work through the stupid crap.
evilokc is offline   Reply With Quote
Old 11-17-2018, 10:30 PM   #2339
mikebte
Installed the kick panels, new door handles (old worn out), installed plug wire heat shields, worked on my fiberglass fan shroud and installed a few other small due dad's I had around. Just keep finding stuff to do.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 11-18-2018, 11:15 PM   #2340
MiraclePieCo
Thanks, all good advice. I have chased the threads, used Permatex thread sealant, then teflon tape, then tried a different plug (both steel however). The only thing I haven't done is try a brass plug instead, so I will do that.
I have a bad back. The last time I took this head off to remove the original stuck plug I was bed-ridden for a week from working bent over the fenders. I just don't have another head removal in me.
Brian
As a teenager I bought a car with a nasty leak in the water neck. Not knowing what else to do, I tossed in 2 cans of Bars Leak. I drove that car for several years, including taking me on regular 3000-mile round trips to college and it never leaked another drop.
Old 11-18-2018, 11:36 PM   #2341
evilokc
a week ago I went to close the door and it didn't shut right. as I checked it out I found that the hinge pin on the lower hinge had fallen out. some idiot put the hinge pin in from bottom with the nut on top. installed that way if the nut comes off the pin falls out which is exactly what happened here. installed the opposite as it should be if the nut comes off it will fall but the pin will remain in the hinge allowing normal door function. I found the hinge pin down in the abyss and reinstalled. its just a pin but aligning the 3 holes by myself was fiddly. im glad its all back in and working great. I also adjusted the fast idle. ive never messed with it and now that its cold it needed a small adjustment. all good now.
Old 11-18-2018, 11:49 PM   #2342
MARTINSR
MARTINSR's Avatar
Well, I was in a hotel last night and spent my 5 minutes going through a Filling station catalog making a list of things I need for the parking brake. The thing is I need to look is exactly what year my cab is, some of the parts split from 51 to 52 so I have to nail that down.
Brian
1948 Chevy pickup
Old 11-19-2018, 10:07 AM   #2343
evilokc
winter is here. I guess I will test out my heater next weekend.
Old 11-20-2018, 11:14 AM   #2344
whitedog76
Enough said?
whitedog76 is offline   Reply With Quote
Old 11-20-2018, 12:51 PM   #2345
mikebte
Originally Posted by whitedog76 View Post
Enough said?
Looks like you are making progress. Very nice
Old 11-20-2018, 05:44 PM   #2346
whitedog76
So, I burnt through some cut off wheels today. I got 1 left now. Anyhow, I have the boxing plates tacked in now.
By the looks of my previous pictures, I think I need to clean off my phone. I guess I shouldn't be using that angle finder app so much... LOL
Old 11-20-2018, 05:57 PM   #2347
MiraclePieCo
I took my truck back to the exhaust shop today for a redo. This time they nailed it - exhaust looks great, works great, sounds great, and now is far enough below the frame rails that it's not overly close to the fuel lines, brake lines and wiring, plus I have room to get my hands in there for maintenance. This is the photo I took them of how I wanted it done - not my truck but now my exhaust looks just like this:
Old 11-20-2018, 06:23 PM   #2348
mikebte
I got all excited as if that was your set up. Looks very nice. That is the way to go for sure.
My YouTube:
Old 11-20-2018, 10:16 PM   #2349
MiraclePieCo
Thanks, I'm excited too. That pic came from Hot Rod magazine's online articles. Unfortunately I didn't take any pics while mine was on the rack but except for being one-piece tube instead of segmented together it looks exactly like that, so you get the idea. Even my trans crossmember is the same (except I fab'ed mine myself).
Old 11-21-2018, 02:50 PM   #2350
svr
svr's Avatar
Ya, interior and firewall painted, get it on the frame and do something different for a while
