Old 02-13-2016, 05:49 PM   #26
S10Fan
Old Heap Driver
Re: Engine miss, no miss codes
Started the truck to move it and suddenly the darn thing runs like a top. No miss, drives great. I've run up 50-60 miles this week with no issues at all. SMH!!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 06-05-2016, 08:34 PM   #27
S10Fan
Old Heap Driver
Yet another update.................
The truck began bucking and jumping again last week. Starts and idles fine, no fuel smell, but, the fuel pressure is down to 48-50 lbs and drops like a rock at shut down. The fuel pump has less than 500 miles on it, and as was the case before, no codes. I'd gladly buy a new spider/regulator assembly from Rock Auto, Delphi, if I thought for sure it would fix this thing.
Bryan
Old 06-06-2016, 06:38 AM   #28
speedygonzales
speedygonzales's Avatar
What you have to do is eliminate the pump or the FPR or the injectors, to figure out which one needs changing.
If you block off or partially block the return, the pressure should come up. If it does, that indicates the pump is up to task. If it does NOT that indicates it is shot.
I've also seen the tubing in the sending unit cause an issue but that still puts the problem back at the tank.
Now let's get back to the part of the test that shows the pressure comes up when you block the return. If the pressure comes up, then you have a problem with the injector unit. Most likely the FPR. In the Vortec's, the brilliant engineers came up with the idea of putting the entire regulator UNDER the upper plenum. There by not requiring a hose to the vacuum port. It's just wide open to the inside of the intake. So if the diaphragm gets a hole in it, it dumps the fuel right into the intake.
If this is the case, you should check the smell of the oil on the dipstick because it can get contaminated with fuel and get diluted.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 06-06-2016, 12:31 PM   #29
S10Fan
Old Heap Driver
Thanks, I'll check it out this evening.
Bryan
Old 06-08-2016, 05:32 AM   #30
S10Fan
Old Heap Driver
Spent a few minutes with the truck last night.............
Key on, 60 lbs.
Running, 50ish, jumps towards 60 when pressing the pedal.
Key off, now the pressure holds for quite a while.
Planning to round up a longer hose for the gauge this weekend so I can drive around the neighborhood and see what happens.
Clamped the return line at the tank area, the gauge would flutter up and down, just a pound or two.
Bryan
Old 06-08-2016, 09:28 PM   #31
1mrtimk
How is the antifreeze level?
My 99 5.7 ran good until under a load at 55 to 70 mph. The truck would loose power and shudder until I would pull over and let it idle until it evened out.
I was losing a small amount of antifreeze so I did a leak down test on all cylinders. Number 5 and 6 both ended up having small cracks in the heads.
I put on a rebuilt set of heads and all is well.
Good luck!
1mrtimk is offline   Reply With Quote
Old 06-09-2016, 05:59 AM   #32
S10Fan
Old Heap Driver
Good luck!
I haven't performed a compression check, but I'm not losing any fluids and the plugs look good, all the same.
Bryan
Old 09-06-2016, 11:41 AM   #33
S10Fan
Old Heap Driver
Planned on spending the morning checking the truck from tank to throttle body. Fired up the truck last night to move it into a better position to work on, it stumbled and cut off three times in 30 feet.
Pulled the pump (man I like the access hole I cut last time!), the sock, hose, clamps, wiring all looked good. Prior to pulling the pump I disconnected the harness plug that bolts to the cross member just forward of the fuel tank. The bolt holding the plug is very rusty and the ground wire held by the bolt was literally connected by 2 maybe 3 strands of wire to an aftermarket crimp connector. I added (soldered) a foot of wire to the ground wire along with a soldered ring connector. The factory bolt was replaced by a 1/4-20 bolt, star washers, and a nut after grinding a clean spot on the cross member.
I put everything back together and fired it up, runs like a top, drove a few miles with zero issues.
I'm not sure it's "fixed" but I have to believe that poor ground wire wasn't helping things.
Bryan
Old 07-27-2018, 06:07 AM   #34
S10Fan
Old Heap Driver
Nearly two years later all seems to be well.
Bryan
Old 07-27-2018, 10:12 AM   #35
speedygonzales
Who'd have thought there was a ground point there!
Thanks so much for sharing and updating us. Who would ever thought there was such an important ground point there of all places.
Now that we are smarter for this information, we can check to be sure we won't be having the same problem.
Pride and joy
Old 07-27-2018, 01:31 PM   #36
Tom
driving is in my blood
Tom's Avatar
FYI 50psi while running was the give away, thats way too low. Glad you found the reason for it.
Old 07-30-2018, 12:49 PM   #37
speedygonzales
Where did you see him say he had 50 PSI running?
Pride and joy
Old 07-31-2018, 10:11 AM   #38
Big Daddy Bear
Big Daddy Bear's Avatar
A few posts and a couple years back:
Key on, 60 lbs.
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
