Old 10-10-2017, 08:36 PM   #1
chris989
sun super tach
1989 v2500
Any pics/ideas on tach mounting locations. I was going to strap it to the column like we did when we were kids but there is too much stuff on the column to get a hose clamp around. thought about the dash, or getting a small tach and installing it where there is a blank under the volts.
Chris
chris989 is offline   Reply With Quote
Old 10-12-2017, 04:37 PM   #2
Desert_Eagle02
Re: sun super tach
My current truck has one strapped to the column. I like it there, easy to see when needed. My old truck had one that the previous owner mounted on the dash. I didn't really like it there, and it also required screwing it into the expensive dash pad. So I wouldn't recommend that. When I redo my gauges, I'm going to put the tach where the gas gauge is, and then move the gas gauge to the blank.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 10-13-2017, 09:10 AM   #3
cadillac_al
Re: sun super tach
I think they look cool strapped to the column.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-13-2017, 11:21 AM   #4
chris989
Re: sun super tach
What year truck do you have? The column was my first choice but no where can i get the hose clamp around it with out something in the way. (key, blinker, tilt)
Old 10-13-2017, 12:53 PM   #5
Desert_Eagle02
Re: sun super tach
It's a 1978. I don't have tilt, but I have a lot of room on my column. I imagine if it did have tilt it would still fit. The clamp is probably about a half inch wide, and I have the tach as close to the gauge bezel as it can comfortably go.
1978 GMC K25
Old 10-13-2017, 05:18 PM   #6
truckin 79
Re: sun super tach
I have a the smaller Sun Tach II mounted toward the bottom of column. Oop upside down but you get the point
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
