01-04-2017, 10:54 PM | #1 |
1950 Split Hood Rear Center Support Bracket???
I started to put the 2 halves of my 1950 hood together when I noticed I am missing a center rear support bracket.
Does anyone have a picture of what this bracket looks like or even better a source or part number to buy a new one? I have one bolt broken off, will need to drill that one out. Thanks,
Curt Brentwood TN 1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260 1957 GMC 100 |
01-05-2017, 12:11 AM | #2 |
Re: 1950 Split Hood Rear Center Support Bracket???
Not sure if repo is available. I have a used one for $25 . Thanks
01-05-2017, 08:50 AM | #3 |
Cool, I will take it. Let me know how we want to handle payment.
01-05-2017, 11:46 AM | #4 |
Ok let me take one off today. About 5 degrees now but should be a balmy 10 degrees by lunch. Thanks
01-05-2017, 11:51 AM | #5 |
As a side note, I've been removing a lot of twisted-off bolts on the sheet metal panels on my truck. Drilling them out works, but is kind of time consuming.
What seems to work best is to heat up the fastener with an oxy-acetylene torch until it is cherry red then back it out with a vice-grip. So far it has worked 100% of the time. |
01-05-2017, 11:56 AM | #6 |
Thanks, take your time and don't freeze yourself It will be a few weeks before I really need it but am ready for it when you are.
01-05-2017, 11:57 AM | #7 | |
01-05-2017, 03:18 PM | #8 |
Here it is . Pm sent with payment info. Surface rust but will clean up nicely.
01-05-2017, 03:28 PM | #9 |
Thanks! Money has been sent.
