01-07-2016, 04:43 PM | #1 |
Cup holders instead of seat belt holders
I've seen console reproductions with cup holders, but I'm wondering if my original console can accommodate cupholders instead of the belt holders. Someone on another thread said it was 2 screws, so that doesn't sound like it would be the whole top half.
What part of the console changes, and how invasive is it, and where do I get the cupholder part? Thanks in advance for any info! I'm sure I'll make a lot more use out of cupholders than selt belt holders, especially since I have 3-pt retractables now.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-07-2016, 04:47 PM | #2 |
70+ ( Old Skool Club )
Re: Cup holders instead of seat belt holders
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-07-2016, 05:21 PM | #3 |
I've got a couple consoles of each type, but they're about 2000 miles away, so I can't compare them side by side.
If I recall correctly, the seat belt portion of the early consoles is integral (molded into) the top portion of the console. The cup holder portion of the later consoles is removable and held in place by 2 or 4 screws. You MAY be able to surgically remove the seat belt portion and add the cup holder portion, but I think some additional fabrication may be necessary to support the cup holder portion. Since the hinged tops and chrome trim rings are the same size, it's reasonable to assume the front section housing the cup holders would be the same size as the seat belt section. I've seen billet cup holders to replace the factory cup holders, but I think you'd need to buy the factory cup holder section used. Maybe someone would trade top sections with you. I know I would. EDIT: Here's a link to a parts thread that has pictures of both types for comparison. http://67-72chevytrucks.com/vboard/s...hlight=console Also... the cup holder consoles use a different hinge for the lid. Jim Last edited by FirstOwner69; 01-07-2016 at 05:47 PM. |
01-07-2016, 05:55 PM | #4 |
the console in my trk has cup holders. it sits in there with a couple screws. bad news is ya got to take the chrome strip off, which is doable but a little tricky. maybe the older consoles are one piece. All the blazer guys have these consoles. maybe check on the blazer forum.
01-07-2016, 06:14 PM | #5 |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-07-2016, 06:46 PM | #6 |
I cut my seatbelt console to use a cup holder drop in, its 2 screws
01-07-2016, 06:50 PM | #7 |
01-07-2016, 07:27 PM | #8 |
Old member
This is a link to mine. I put the new billet cup holder in mine.
Taking the trim off wasn't so bad with a good peir of needle nose. Twist the tabs and it pops off. http://67-72chevytrucks.com/vboard/s...d.php?t=648379
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-07-2016, 08:33 PM | #9 |
Dave, this would look good in your truck. It's on forum member t korinek's Craigslist ad in Phoenix. I wonder if it's still available.
http://phoenix.craigslist.org/evl/ptd/5391516118.html Jim |
