04-14-2016, 11:18 PM | #1 |
Its a Truck Thing......
Lifted 4x4 Brake Hoses
What brake hoses are you guys using for lifted trucks? Got a 70 with a 73 disk front Dana and about a 4 inch lift.
Thanks, Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
04-15-2016, 12:23 AM | #2 |
Re: Lifted 4x4 Brake Hoses
I used Offroad design. I have a Dana 60 up front not a 44. But they have lots of line configurations. You can call them if your not sure what to order.
White K20 |
04-15-2016, 12:32 AM | #3 |
04-15-2016, 12:47 AM | #4 |
DOT approved......I hope
04-15-2016, 12:01 PM | #5 | |
Point taken about measuring the lines with the axle dropped. I have been looking at all these 4X4 sites and mostly what I am seeing is about a 23 inch line for the lift on the truck that is being sold. Smitty
04-15-2016, 01:42 PM | #6 |
ORD for sure. They offer different lengths for lifted applications and different needs.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
04-15-2016, 02:20 PM | #7 |
user # 2756
I used ORD too, front and rear. Swapped in dana 60 and 14 bolt.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
04-15-2016, 11:45 PM | #8 |
ORD! Dot Approved, says so in the hose itself.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-16-2016, 09:40 PM | #9 |
Skyjacker ss braided D.O.T. Approved
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
04-18-2016, 07:54 AM | #10 |
Quality factory replacement mid-late '70s C/20 brake hoses are what I use. I tell them '78. NAPA PNs are rear - 36759 and front - 36765. I just peel the unneeded clip-on tabs off that aren't needed.
I have bought the expensive braided ss hose kit for a '72 K/20 from one of the companies mentioned above and the rear hose was wrong, wrong gender on the axle end and a size too big. I had to pay even more to have Inline tube to make one that worked as well as the correct t-block. Factory spec brake hoses do the job just fine. If you just need longer hoses and don't care about adding hoses (you don't really see) for a look, the C/20 hoses do the trick. I like that they do the trick while looking stock
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-27-2016 at 05:23 AM. |
