04-21-2019, 05:57 PM | #1 |
roller tip rocker ? sbc
so i have been driving my brand new GM long block L31 vortec and she is doing good . i have a set of brand new comp cams SELF-aligning roller tip rockers 1417-16 part # or https://www.summitracing.com/parts/c...7-16/overview/ to show you what i have . these are from a left over old project i never used them on . pic dont show them as self aligning but they are .
would i be crazy to install these on the engine ? would i see much of anything ? otherwise what do i do with them ? try and sell them i be lucky to get even close to new at there price point . thanks for any real world feedback you guys might be able to give me .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-21-2019, 08:38 PM | #2 | |
Re: roller tip rocker ? sbc
04-22-2019, 01:59 PM | #3 |
Engine Masters did a great test on roller rockers. Basically you gain nothing.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
04-22-2019, 03:24 PM | #4 |
Why take the chance of something going wrong when there is nothing to gain.
In other words if it ain't broke don't fix it. |
04-22-2019, 05:54 PM | #5 |
I am with GaryD
Maybe spend your money on some shiny parts instead. Chrome valve covers with your name of the vehicle. Like Betsy or whatever you call your vehicle. Posted via Mobile Device |
04-23-2019, 08:05 AM | #6 |
I wouldn't mess with it either if it is running fine now.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-24-2019, 12:24 PM | #7 | ||
"I ain't nobody, dork."
I have the Summit Racing long slot roller tip rockers in my 350. Bought them years ago when I built the engine. They were all the rage back then and I basically bought them as an "upgrade" from stock stamped rockers. They tend to be a little noisy at low RPM... and there is no significant gain whatsoever.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-24-2019, 11:03 PM | #8 |
In the late, great John Lingenfelter book, he states that usually with the valve spring pressure the roller tip don't actually roll anyway. The slide just like the stock rockers do. But, he also stated they are closer to the advertised ratio of 1.5 or 1.6.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
04-24-2019, 11:29 PM | #9 |
thanks for all the info so far .
just wish i could find a good engine dyno result for JUST the roller tip rocker change . lots of them were engine masters but almost all removed from youtube and on there site only now .
04-25-2019, 11:51 AM | #10 | ||
I have a subscription to MTOD and watched it last night. The roller tip rockers made no change. The main thing to take away from that test was as spring pressures go up, so does the deflection of the stock SBC 3/8" rocker arm studs. Where horsepower was gained was with a 7/16" stud and/or some kind of deflection control of the 3/8" stud (i.e. a stud girdle). Also using a 1.6 ratio vs. the stock 1.5 ratio made more power. But that might also be because of the head they used. They were spinning that Small Block to 7,000 RPM's too. Which most street engines will not see.
Gary
04-25-2019, 02:38 PM | #11 |
cool info thanks a lot on that one .
