05-05-2003, 11:59 AM | #1 |
Got big-block?
project Daisycutter update.....after POR-15
Here's a couple of pics after I put on 2 coats of POR-15 on the rear of the chassis. Came out nice and slick. Now to put on a coat of the ChassisCoat paint for a topcoat.
Notice large black spot on driveway where I knocked the freakin' can of POR-15 over; that was expensive... I plan on cutting that left rear exhaust hanger off, so I didn't paint it. Just waiting on the rebuilt rear end so I can POR-15 it, then I can assemble the rear of the frame/suspension, move the bed back to its mounts, then repeat the whole process for the front of frame. Complete frame and suspension should be done by the end of May. Off to the bodyshop in June. Now to go cut the drips of POR-15 out of my hair......SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
05-05-2003, 12:00 PM | #2 |
Got big-block?
pic2
05-05-2003, 12:21 PM | #3 |
Looks real nice. Do you think the top coat is required for the frame? I'm a little confused from the info I read whether the top coat is only necessary if sun is going to hit the paint, or if it should be always used.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-05-2003, 12:54 PM | #4 |
Nothing fits but the oil
At least your driveway won't rust...frame looks good!!
Land of the free Because of the brave |
05-05-2003, 12:59 PM | #5 |
ready for reassembly
looks great! how much por-15 have you used so far(minus what you spilled that is )?? How much is it gonna take to do the whole frame? Just curious cuz I want to know how much to order when i finally paint mine. Thanks
Jason
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
05-05-2003, 04:02 PM | #6 |
Got big-block?
I've probably used only a pint so far. That's doing half the short frame with 2 coats. A little goes a long way. I think a quart more will do the rest of the frame, the rear end, front suspension and misc.
I'm going to go ahead and chassis coat the whole frame. I know it says you only need to do the parts that will receive direct sunlight, but what the heck, I'll be right there - might as well do it all. SC
05-06-2003, 06:58 PM | #7 |
chevelito
so was that done with a brush or spray? looks good, I might just do that.
New deadline...when my son can drive. Aloha from Honolulu, HI |
05-06-2003, 07:15 PM | #8 |
Got big-block?
It was done with a brush.
05-06-2003, 08:07 PM | #9 |
That looks real nice.
How did you strip off all the oil and stuff that usually is coated on the frame? |
05-06-2003, 08:45 PM | #10 |
Navel Inspector
Just a couple of questions.
Are you doing this all in your drive? If so its good to know I can do some stuff without a garage. Although I don't even have a paved drive. I rented a house next to my grandmothers to help her with things she need done. It looks good. I am assuming ( I have no body shop exp ) That what you put on prevents rust.
Nice Job!!! David
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
05-06-2003, 11:30 PM | #11 |
Got big-block?
Yep, doing it all in the driveway. The 1 car garage is full of parts/tools.
Spray wash the frame to get as much gunk off as you can, then go to the dollar store and get 3 or 4 cans of EZ-OFF oven cleaner. Spray the EZ-OFF all over the part you want to clean, then let it sit overnight. Then wash and scrub the part clean. Let dry, then coat with whatever rust-sealing paint you are going to use. SC
05-06-2003, 11:40 PM | #12 |
Thanks for the tip. I would never have thought of using oven cleaner. I want my frame to look like yours when done.
Next question. What kind of bristle did your brush have when using the por-15? |
05-06-2003, 11:53 PM | #13 |
I have used a similiar product on frames......and interior before upholstery, and I used the 3" wide rollers from Home Depot. They are great for frame rales and the paint will lay out nice when dried, there is no sign of how it was applied.
05-07-2003, 04:16 AM | #14 |
Hmmm, great ideas
05-07-2003, 07:04 AM | #15 |
I just did my frame,I used a quart of POR 15 sprayed it on and then before it dried all the way,when it was still tacky I sprayed over it with epoxy black paint and let them both set up together.This way there is no need to topcaot the por 15 .My neighbor did his this way and the guy I bought the POR 15 from said that it would work fine.It came out great.
05-07-2003, 12:33 PM | #16 |
67 is sold
Frame looks great
I was discussing that very product with a local vendor at a show over the weekend. It is on my list |
