Old 06-23-2018, 10:37 AM   #26
Bigdav160
Bigdav160's Avatar
Re: 350 for towing?
Unless you already have it, a Victor Jr for vortec heads is $300-$350.
I don't know how well matched it would be on that combination. If it was my truck (I loved my '93 4x4 Suburban) I would consider a complete L31 from a donor. New fuel pump, some wiring changes, computer and you're done
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-23-2018, 10:47 AM   #27
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 350 for towing?
I agree that the Victor Jr will not be the best manifold for towing. It's RPM range starts well out of the low end TQ area, where you need it most when towing.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-23-2018, 04:35 PM   #28
Kudzupatch
Kudzupatch's Avatar
Re: 350 for towing?
Read up some peoples experience with TBI and single plane intakes. Carbs need vacuum signal to pull the fuel through while TBI doesn't. Found several people using Victor Jrs and loving them. A couple of tuners say they actually make better power low with a single plane and injection.
http://www.cpgnation.com/forum/threa...e-plane.25871/
Kudzupatch is offline   Reply With Quote
Old 06-23-2018, 05:17 PM   #29
Tom
driving is in my blood
Tom's Avatar
Re: 350 for towing?
Correct, single plane intakes can work well with fuel injected setups. I'd just get a performer RPM with an adapter plate myself but I've only ever run carbs or factory vortec injection with my setups.
Old 06-23-2018, 05:50 PM   #30
Eddie H.
Eddie H.'s Avatar
Re: 350 for towing?
I have a 99 Yukon with a stock L31 350, 3:73 gears, and 4L60E trans. I have towed a 5000 pound boat and trailer, and a tandem axle flat bed trailer with a 5000 pound vehicle on it ( close to 7000 pounds) numerous times without any problem.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
