01-09-2018, 03:32 PM | #1 |
Any feedback on these headlights?
I want to try these on my 68 C10. Has anyone used this exact light for their truck?
https://www.summitracing.com/parts/h...eviews/?page=3
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
01-09-2018, 04:00 PM | #2 |
Re: Any feedback on these headlights?
I haven't used them, but after reading the reviews I'm impressed. I was already planning on putting in headlight relays; I might just upgrade to these lights as well. I want to see better but keep the original look.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-09-2018, 04:06 PM | #3 |
I am also impressed with the reviews. One of them is from an owner of a 68 C10 like mine. These look good, and I am tired of the dangerous low-light OEM ones. Low-light combined with drum brakes, and stupid pedestrians walking at night with ear buds, looking at their cell phones instead of where they are going all make for a BAD time.
01-09-2018, 05:06 PM | #4 |
Old member
Before any other upgrade of lights I suggest the relay kit first. It will amaze you at how well it will work with your regular lights. But adding the H-4 bulbs and housing is a great addition too!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-09-2018, 11:43 PM | #5 |
Junior Member
You might also check into Cibie. Similar, but a little more expensive. I used Hella on my motorcycle and Cibie on the C10. I like the Cibie better. Either would be a big improvement over a sealed beam, but the Hellas don't seem to be as sharp, at least to my eyes.
01-09-2018, 11:56 PM | #6 |
Who Changed This?
The important thing is not to over drive your headlight's reach.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 01-10-2018 at 01:03 PM. Reason: unneeded words deleted |
01-10-2018, 12:07 AM | #7 |
FWIW I have Jeep Wrangler headlights any 1972 K10. Bought them as take-outs from a 4x4 shop that swapped them for a customer to LED's.... Cheap...I have a relay set-up as well, bought conversion harness's on the auction site for $4.99 ea,,
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
01-10-2018, 12:16 AM | #8 |
Interested! I rarely drive my truck at night anymore. But this could save my life one day. And maybe someone else's.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-10-2018, 12:21 AM | #9 |
I have not run that exact headlight but I have the Euro sister to that in my Burban and have run them in other cars for years.
http://www.bjsoffroad.com/Hella-Euro...amp_p_980.html I have been very satisfied with them. Use quality bulbs and you won't be disappointed. One thing though is that back of the light is larger than stock and you will have to enlarge the hole in the core support to get the light to fit with the dust cover over the bulb socket. I have a short write up on page 5 of my WMB thread (Link below) I hope this helps.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-10-2018, 12:22 AM | #10 |
Relay kit?
01-10-2018, 12:35 AM | #11 |
You can buy a kit (I think LMC and other vendors carry them) or you can just get a couple of Bosch relays and wire it yourself. Here's a link that might help:
http://67-72chevytrucks.com/vboard/s...eadlight+relay
01-10-2018, 12:35 AM | #12 |
A common upgrade of our head light wiring. The factory wiring is the minimum size usable for the OEM headlamps and it will limit the output of the lights due to voltage drop. Installing a larger guage supply wire to the lights solves the problem. Then you use relays to control the new power feed to the lights. There are literally dozens of write ups on how to do this. Not to mention plug and play kits you can buy. I have done it to my Burban as my new H4 bulbs draw more power than the dimmer switch will handle.
That and having good ground connections will do wonders for even stock bulbs.
01-10-2018, 01:01 AM | #13 |
Thanks, I red about 12 different threads and they confused me-these are great.
01-10-2018, 10:24 AM | #14 |
relay kit and the Hella E codes and you'll swear you're driving a different truck.
REAL German-made glass housings and lenses - not chinese-made plastic. They are THE cat's balls of headlights. No mods to my '67 radiator support to use these lights. Remove old sealed beams, installed Hella housing. Plug and play. I bought mine from Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
01-10-2018, 04:11 PM | #15 | |
Hella, Bosch, Carello, Cibie, Lucas, etc. European made H4 headlights are the real deal and will be far superior to anything plastic or sealed beam. My favorites are vintage Cibie followed by Bosch and Hella. Aiming them properly is also really important. If you want to run higher rated bulbs our lights switches have circuit breakers that will trip. Relays are must at that time.
Saskatoon, Saskatchewan Canada |
01-10-2018, 10:49 PM | #16 |
I also run the Jeep Wrangler head lights. Picked them up on eBay $40 just look around. One of the best things I did. They have a good cut off. Funny thing is they work better than the one on my Wrangler.
AJC |
01-10-2018, 10:54 PM | #17 |
Some interesting reading at "daniel stern lighting". He gets into the bulbs and i followed his suggestions with cibie's and a shielded low/high bulb and very happy with the results. I did cibie's in the late 70's and knew what i wanted. I e-mailed him with the light beam description of the low beam being wide, lighting both ditches with the hockey stick hook up the passenger's side ditch, and high beam being 2 pencil beams that really lit up the road a long ways away. He supplied me with e code cibie's and believe it or not 55/60 watt shielded bulbs that are fantastic. I told him i ran a 100 watt high beam in the 70's and he was so confident on these 55/60 watt bulbs he said he would refund me if i was disappointed. I did pay near retail but his help was the best and my opinion is my night time vision is well worth a one stop shop with experience.
01-10-2018, 11:00 PM | #18 |
I have used the H4 bulb and found relays are a must...been buying these with good results ...FYI
https://www.ebay.com/itm/H4-Headlamp...72.m2749.l2649 |
01-13-2018, 01:18 AM | #19 |
What years of Wrangler work for this?
01-13-2018, 01:36 AM | #20 |
ttt
i also want to know what year wrangler headlights work on my 71 cheyenne
i survived cancer and kidney stones, but my kids are killing me. |
01-13-2018, 01:57 AM | #21 | |
I think my headlights are from a 2010 or so wrangler. Call a 4x4 shop as they do lot's of LED swaps on these jeeps and usually keep the take outs lights. Don't forget the relays..
01-13-2018, 07:35 AM | #22 |
Hella is quality. The nice thing about the Hellas shown is they don't stand out as newfangled modern bulbs. Those other upgrade bulbs are fine if you want your headlight bulbs to be the focus, but modern light that doesn't wave a flag is just classy.
01-13-2018, 07:49 PM | #23 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-14-2018, 02:05 PM | #24 |
Subscribed
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
