09-03-2007, 01:56 PM | #1 |
67 chevy SWB Fleetside
can't turn the key in the ignition
Looking for any advise. We own a 04 Avalanche. Last night we needed to move it back a few feet so my wife hopped in, turned the key, put it in neutral and let it roll back about 10 feet. She put it back in park, removed the key, got out and locked the door.
Today I hopped in and I can't turn the key. I tried the other key (both original and no luck). I can't find a blown fuse anywhere (thought maybe there was an electrical interlock) and I disconnected the battery for an hour hoping that might change things but no luck. Anyone have any other ideas? Does the ignition have an electronic interlock that will stop the key from turning? Only 45,000 miles on the truck. Thanks
67 Chevy C10 Short Wide 350/350 ... Front Discs ... ECE Lowered 2.5/4 Vintage Air ... Oak Bed Floor ... Painless Wiring Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake Ididit Column ... VDO guages |
09-03-2007, 02:22 PM | #2 |
Re: can't turn the key in the ignition
Did you try turning the steering wheel one way or the other? If there is some tension on the steering wheel lock mechanism, then you can't turn the key. That would be my best guess.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
09-03-2007, 02:49 PM | #3 |
steering wheel lock is not engaged. I can turn the wheel from side to side.
09-03-2007, 03:37 PM | #4 |
As far as I know there is no electronic interlock on these trucks. I could be wrong though. Here are a couple of pages that I took from a complete wiring diagram that I got from AHDOL (Good deal for $12 IMHO) for my 04 Silverado. It doesn't show any type of interlocking system.
Can you move the shifter at all? Maybe it didn't go all the way back into Park before she removed the key? If not, then I think I'm stumped.
09-03-2007, 05:20 PM | #5 |
thanks for the advise and the pages. Those do look handy. The shifter is in park. I can move it toward me, but not down and into any gear. I am stumped too. I hate to do it but I'll probably have to tow it to the dealer tomorrow.
09-04-2007, 11:42 AM | #6 |
For anyone who is interested. . .
I found a gm mechanic on line who shared a service bulletin with me for 99-05 gm vehicles. It stated that the lock cylinders are prone to collecting enough of a dust build up to impede the pins from retracting correctly. The recommended solution was to shoot 60 psi of compressed air or brake cleaner in the lock cylinder to dislodge the material. It sounded far fetched after all I had tried but I gave some brake cleaner a shot and problem solved. I think I will remove the lock cylinder and clean it thoroughly and then oil it with some light oil.
09-05-2007, 10:31 AM | #7 |
GREAT info to know since I have a '99 Chevy 1/2ton. Thanks!!!!!!!!
09-05-2007, 09:10 PM | #8 | |
Bloo
just a word of warning zacut-- youll probably have to have the security relearned if you remove the cylinder. some of the do and some dont, im not positive on a 04 avalanche though
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
