Old 03-28-2009, 07:48 PM   #1
nogaroa4
Lower Control Arms on a IFS....Parallel"
How important is it to get your bottom control arms parallel to the ground, side to side and front to back. I just installed a TCI Mustang 2 suspension and 4 link. I put the frame on a 1.7 degree angle when installing the front cross member thinking that the back would sit higher then the front when the truck was at ride height.
It seems that the frame sits at 1 degree pitch front to back at ride height instead. Now my front control arms pitch back, is that ok?
nogaroa4 is offline   Reply With Quote
Old 03-29-2009, 07:37 AM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Lower Control Arms on a IFS....Parallel"
I'm pretty sure the pitch is built in to the cross member and it should be just welded flat to the frame. Should give TCI a call and ask them.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-29-2009, 08:16 AM   #3
weldvair@embarqmail.
That is fine.
Don Meyer-Mech Engr.
weldvair@embarqmail. is offline   Reply With Quote
Old 03-29-2009, 10:14 AM   #4
71'tahoe
71'tahoe's Avatar
You want your control arms to be tilted to the rear a lil' its for caster. Caster is important because it is what keeps your wheels tracking straight as you drive forward and stop. Of course your toe adjustment helps a lil with this also. Caster is an imaginary line drawn through your upper and lower ball joints. You want that "line" to be tilted to the rear.So if you have your frame sitting level and you were to draw a line through your ball joints then you would want to see the line a few degrees behind center. Even of your cross member was level when you installed it, it will have a certain degree of rake to it if you run a tire that is taller in the rear than the front. Hope this helps and isnt to confusing.
71'tahoe is offline   Reply With Quote
Old 03-29-2009, 04:03 PM   #5
There is all kind of caster & camber adjustment built into the TCI crossmember(controlled by the upper A-arm adjustment). I have installed 5 of these kits & you are fine.
I was one of the first people to use the Must II IFS back in the late 70's When I lived in Columbus. Back then I installed the factory IFS.
Don
Old 03-30-2009, 05:14 PM   #6
1-ton of fun
polishing a turd
1-ton of fun's Avatar
you also want them laying back some for anti-dive on hard braking.
its a little different geometry, but i built about 9* of anti-dive into the front suspension with the frame level, i may lose a little of that depending on the final stance
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
