03-29-2009, 11:43 AM | #1 |
Brake Line
I have converted my 59 GMC over to four wheel disc with dual master power brakes and proportion valve and the rear brake line kit came in and it is all 4an (7/16) but the rest of truck I have put 3an and 3/16 lines will running the two different size lines matter.
03-29-2009, 01:10 PM | #2 |
Cantankerous Geezer
Re: Brake Line
I would prefer 1/4" tube. But 3/16 was used in some factory jobs with discs, so it should work.
Fred There is no such thing as too much cam...just not enough engine. |
03-29-2009, 01:22 PM | #3 |
Hollister Road Co.
Re: Brake Line
-4 AN is 1/4" not 7/16". each -1 is a 1/16".
Disc brakes should be 3/16" line. Drum brakes use 1/4". |
03-29-2009, 06:50 PM | #4 |
Re: Brake Line
Yes you are correct 4an is 1/4 that was my slip up.
Thanks for noting that. Will it matter on braking balance with having 1/4 line on the rear disc and 3/16 on the front disc? Robert |
03-29-2009, 08:15 PM | #5 |
Hollister Road Co.
Re: Brake Line
My understanding is that disc uses 3/16 front or back. Drum uses 1/4". It may throw off the balance. I used 3/16 on mine
03-30-2009, 12:26 AM | #6 |
Re: Brake Line
As long as your master cylinder has the capacity to move the larger amount of fluid the larger size will not be a problem. They are designed as a system with the MS sized to the line and caliper piston volume. Pressure stays the same regardless of line size but you need more volume in large diameter line. Drum wheel cylinder requires more volume than a disc caliper, hence large diameter line.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
