05-05-2015, 04:42 PM | #1 |
does anyone know what master cyl ebay kits use
does anyone know what master cyl the ebay booster kits use i bought one and the master quit on me (they all apear to use the same one)i dont know what make/model its from ,i need to get a replacement . thanks for any help!!
05-05-2015, 05:42 PM | #2 |
Re: does anyone know what master cyl ebay kits use
this is the kit
05-05-2015, 05:47 PM | #3 |
Well, without knowing your application or a link to the auction, I'd say it's the black thing.
Attractive plating though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-05-2015, 07:55 PM | #4 |
05-05-2015, 08:01 PM | #5 |
I don't know, but rest assured it's probably not made in the US. However, neither is much of the stuff you'd get from Advance, Oreily, etc. If you NEED the bracket and connecting gear, it's probably worth a shot - worst case is you'd have to go buy a $20 master at Oreily when it konks out. But, on the other hand - you could do that in the first place and skip the expense. I have to admit, it's a good looking setup for only $189.
You can piece together your own parts, and, if you need a bracket - check out CaptainFab's brackets on this site - he makes great parts. |
05-05-2015, 09:41 PM | #6 |
this setup has been on my truck for a while and it actually works great ,the master went bad and i need to replace it the problem is im not sure what the master cyl. used in the kit were made for .
