Old 04-18-2012, 09:23 AM   #1
jeffro788
jeffro788's Avatar
stereo cutting out
Got another one, I have put in several stereos in these trucks along with amps, speakers, and subs, but for some reason I can't figure this one out. Originally when i bought the truck it had an aftermarket stereo in it that I have now replaced with another aftermarket. When you turned up the radio between half and 3/4, it starts cutting out and gets worse the louder it goes. I have seen this when a vehicle is turned off b/c it is telling you the battery is dead, but this is while running and driving.
I meant to see if the previous owner put a fuse in that is too small and not allowing the proper current flow to power it. It does have the factory harness and I used the adapter and connected it to the radio harness, I have never had a problem doing it this way. Any suggestions?
This is on a 2000 chevy p/u.
1972 Chevy SWB - ZZ4 crate motor, 700r4, makes lots of noise! - SOLD
1987 Chevy SWB - SOLD
2000 Chevy SWB - 6.0L heads, Lunati cam, Whipple supercharger, 3.73 posi, caltrac traction bars, headers, custom tune and Borla race muffler. 500 H.P.
1970 Oldsmobile Cutlass 442 w-30 - original
jeffro788 is offline   Reply With Quote
Old 04-18-2012, 10:36 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: stereo cutting out
If the fuse rating is exceeded the fuse will blow and will need to be replaced for the radio to work again. Pull the unit out of the dash, turn everything on to where it starts cutting out and monitor the voltage between the ground wire and power wire. I'm going guess you will see less than 12v. How much of a system do you have? Just a head unit or amps ect.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-18-2012, 03:16 PM   #3
jeffro788
jeffro788's Avatar
I just have the head unit powering an aftermarket set of components and the pillar speakers, then I have an amp powering one 10" sub, and it isn't a big amp. I had 4 times as much power back when I had my '99 that is basically identical to this 2000 and never had this problem.
With the fuse I was just thinking that the fuse if smaller than rating was just restricting the flow to the radio, I don't think it would blow in this case.
However, I failed to mention that when the radio cuts out, the amp is still getting its signal and playing. I am 99.9% certain that it is not the radio since both of them did it and this one is brand new. I can try to check the volts, but if it isn't producing 14v what do I do? Run another constant power off a different source?
Old 04-18-2012, 09:43 PM   #4
usmcchevy
usmcchevy's Avatar
Check the voltage, if its less than 12ish disconnect the amp. Then does it still cut out? What voltage now? I would rather fix the problem than just find another source of power.
Build thread
LSx Swap FAQ index
Old 04-20-2012, 02:29 PM   #5
jeffro788
jeffro788's Avatar
I definitely want the original wires to work, I just don't kow where to go on this. I will try the volt meter and get a reading this weekend.
The fuse however is the correct amp for the radio position.
Old 04-25-2012, 12:18 PM   #6
jeffro788
jeffro788's Avatar
Problem solved! A tweeter had fallen out of the cup and was disconnected, this caused an abnormal load on the radio and sent it to protection mode. I was beginning to stress out.
