Old 04-23-2012, 04:22 PM   #1
bambbrose
Battery charging issue, some clues?
I've been having one of those lovely intermittent issues the past 3 months.
Here is the rundown:
-Battery has been load tested, and passed without issue (2 years old).
-Alternator has been on-truck tested at parts store and passed easily.
Truck:
2004 GMC 5.3 4x4 SLE Extended Cab 1500
Issue:
Occasionally, upon first start up, I get a "Battery Not Charging" message on the display center. My voltage gauge will show around 11 to 12 volts.
I can hear a very very faint wheeze sound. Not a squeaking belt. Not a grinding bearing, or metal to metal, just a hum. Almost like the hum of an intake sucking in air at idle without the airbox on.
If I drive the truck, after about 1 or 2 minutes of driving, the voltage gauge all of the sudden kicks up the 14.4V immediately, and things are fine from that point onward. It isn't a gradule build up of voltage, but as if the alternator just decided to work out of nowhere. The sound goes away when the voltage kicks up. The sound is so faint you can only hear it with audio off and windows down.
Because it only happens for the brief period in the morning, and at that only once every few weeks, I can't seem to reproduce it for any diagnostics.
I'm worried about it kicking the bucket while on a trip or on a family member, so I'm looking for advice or clues.
The truck has 141k miles, original alternator. Belt looks worn, probably needs replacing sometime soon.
Any ideas on how to check this?
bambbrose is offline   Reply With Quote
Old 04-23-2012, 05:56 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Battery charging issue, some clues?
I'd verify with a meter on across the battery next time it acts up. Or maybe just replace the alt for piece of mind.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-26-2012, 09:03 AM   #3
truckdude239
truckdude239's Avatar
your gauge cluster could be going out?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
