07-29-2015, 08:40 AM | #1 |
TF Passenger Door Mirror Brace
Good morning all. Anyone know who carries an internal brace for passenger side door mirror? I see where the door frame (but not skin) has the 3 holes established, but there is no support brace like the driver's side has. Thanks much, Jim
07-29-2015, 12:34 PM | #2 |
Re: TF Passenger Door Mirror Brace
I did not worry about the brace, I just made a template, drilled the three passenger holes, bolted down the screws and welded the screws to the existing reinforcing plate. Here is a photo.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-29-2015, 02:00 PM | #3 |
Thanks. I was looking at just doing that as well, but didn't know if it would be strong enough if the mirror was bumped, etc. Especially since the driver's side has the brace welded to the inner skin too. Thanks, Jim
07-29-2015, 03:48 PM | #4 |
Good point, I have not painted the door yet so might go back and fab something up, easy bend for a 16 GA piece.
07-29-2015, 09:55 PM | #5 |
never noticed the brace on the drives door
i did the same as orrieg, just drilled the holes 25,000 miles, some at over 100 mph and nary a crack in my door paint
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-30-2015, 10:18 AM | #6 |
Same here. I drilled the holes and used some thick washers on the inside for support. I'm using the five inch round mirrors and have no problem with the mirror vibrating or shaking at highway speed.
07-30-2015, 07:50 PM | #7 |
Thanks guys. Sounds like a reinforced plate with welded nuts might do the trick then - maybe even at 100 plus!
Cheers, Jim |
