Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-10-2018, 06:42 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Help with roof repair
Hey guys! I am currently building a 86 GMC crew cab. However the roof had something sitting on it at some point and there is a dip in the roof. It’s not “horrible” but it’s way more than I’d like to be there. And more than it looks like in the pics. I have removed the I side trim and removed the headliner to access. But there is an inner panel there as well. I’d like not to cut that panel out to access the outer skin, what are my options here? Thanks for any help guys.
--Josh
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=717887
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-15-2018, 06:22 PM   #2
STOCKISH
STOCKISH's Avatar
Re: Help with roof repair
Anything??
--Josh
Old 04-15-2018, 06:32 PM   #3
PDW HOTRODS
PDW HOTRODS's Avatar
I would try a few suction cups for glass, clean the roof and they should stick. Motorcycle tie downs to some rafters or something overhead, pull up, and tap around the edges lightly with body hammer.
PDW HOTRODS is offline   Reply With Quote
Old 04-15-2018, 07:54 PM   #4
6erWebb
Yeah its kinda hard to tell but if you dont have any hard creases some suction cups will pull it out. Metal has a memory all you need to do is coax it back to its home. If you see wrinkles though like the source of a dent youre in for a little hammer dollie work. in which case youll need to cut out that inner panel to access.
6erWebb is offline   Reply With Quote
Old 04-16-2018, 12:07 AM   #5
andyh1956
This is what I would try PLUS drill some holes in the inner panel & squirt some foam insulation in there. It will expand & once it sets up you can remove the suction / traction apparatus & it should stay.
By the way my son lives in Franklin!
andyh1956 is offline   Reply With Quote
Old 04-16-2018, 10:58 AM   #6
esbstuff
Try here: http://67-72chevytrucks.com/vboard/s...d.php?t=572601
esbstuff is offline   Reply With Quote
Old 04-16-2018, 12:35 PM   #7
tinydb84
tinydb84's Avatar
Do not use foam insulation. It will hold moisture and rust the roof out in no time.
Use a stud gun and hammer work. Put your high crown areas back in place first and see what you have left afterwards. It will be a bit more difficult without having access on the back side to do dolly work but you can do it.
David
Instagram: myfabguy
Old 04-16-2018, 03:01 PM   #8
BLP86
STOCKISH
Here are 3 pics of the work I had to have done after I had the cab stripped and found out that someone had bashed the roof in, then filled it with body filler. I think I know who the sob was that did it but that is another story. The roof was pulled successfully, with minimal filler for final finish.
BLP
BLP86 is offline   Reply With Quote
Old 04-16-2018, 04:36 PM   #9
Wgesnerjr
Wgesnerjr's Avatar
I would try a paintless dent repair outfit. They can do wonders.
If not, the suction cup thing would be good. I have tried to use Harbor Freight ones with no luck.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
