01-11-2010, 10:29 PM | #1 |
Front tow hook options
What kind of options are there for tow hooks on the front of these trucks? I am not looking to buy a set of the super expensive stock ones since I plan to use these. Pics would be great also. This would be on a 4x4 if it matters..
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban Last edited by 67chevy2wd; 01-11-2010 at 10:30 PM. |
01-11-2010, 10:37 PM | #2 |
Re: Front tow hook options
go to tractor supply if you want $10 one's to use...
originals are $200-$400 depending on style... 60-68, 69-72 and 72 extreme bends not my pics...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 01-11-2010 at 10:46 PM. |
01-11-2010, 11:05 PM | #3 |
Thanks for the pics, I am not looking for $10 cheapies, I want something that will hold up if I get stuck.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
01-11-2010, 11:07 PM | #4 |
I have an original set for my 68, they are tough as nails...
the cheap one's have a 10,000 lb rating though.... You can bolt them to the bottom of your frame rail pretty eaily. northerntool.com has some like this for under $10...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 01-11-2010 at 11:08 PM. |
01-11-2010, 11:10 PM | #5 |
might have to save up for a set of 67-68 or 69-72. I like the way they look. A set of extreme bends would be nice but they bring alot of money if I remember right.
01-11-2010, 11:14 PM | #6 |
prices have been lower lately... check the parts board...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-12-2010, 12:13 AM | #7 |
SWB 4x4 Collector
The 73-80 styled tow hooks are pretty stout too. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
01-12-2010, 12:17 AM | #8 |
FWIW, I've got a set from northen on my jeep and haven't had any problems with them and I've been hung in some pretty nasty holes. Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
01-12-2010, 01:33 AM | #9 |
20' Daredevil (Ret)
I have had some like this on my K20 for many years and have put some hellacious loads on them. They take it all in stride, nothing bent and nothing broken.
01-12-2010, 09:29 AM | #10 |
I had/used the ones from a 73-up for many years and didn't have any problems.
01-12-2010, 12:14 PM | #11 |
The 73-up hooks are plenty strong, and are also easy to find. I had a 80 chevy stuck bad in the winter once, hooked up with a large tow strap and ripped off the front of the frame rail, and bumper. The tow hook was still good though.
01-15-2010, 03:22 AM | #12 |
Damn lol. Thats a good hook then lol
05 Chevy 3500 Crew Cab Dually Sold 1984 Custom Deluxe K/30, 350 SBC with 4 Speed, 6" Lift, 35" Boggers, Headmen Headers, Custom Full 3" Dual Exhaust, Qualitex Buckets with Flip Center Console |
01-15-2010, 07:32 AM | #13 |
$10 cheapies will take anything you can throw at them.I`ve bent frames hooking up to them.All hooks are stronger than the frame.They come in chrome few a few dollars more.
01-03-2011, 11:22 PM | #14 |
While you guys are talking tow hooks; I have a true 1972 4x4 frame that only has that one big hole ( like 1" in diameter ) on the frame horn. This tells me that not all 4x4 frames came from the factory drilled for hooks, right?
Can somebody who has a pair of 72 hooks tell me what the center to center bolt hole pattern is for the two holes that hold them in place? Are they angled back at the top? Thanks for your help guys. 72longbed Last edited by 72longbed; 01-03-2011 at 11:22 PM. |
01-10-2011, 10:57 AM | #15 |
With enough yanks i broke two tow hooks here's what happens when a barge rope knocks are your back door
