03-23-2019, 12:09 AM | #1 |
72 400 Transmission
Anyone know how to read the plate on the side of this 400 I got other day. reads 72-CJ 428 and the Trans SN from what I found 72 truck year and 396 BB does this sound correct or ? Thanks
03-23-2019, 10:16 AM | #2 |
Re: 72 400 Transmission
any trans guys here ??
03-23-2019, 01:31 PM | #3 |
There were no 396 engines in 72 (so am not sure the SN lookup you used is reliable), however, TH400 would be the correct trans for a 72 (2WD only) that came with a 402.
TH400 SN is usually stamped on driver side just above the pan rail - any additional info there? |
03-23-2019, 02:01 PM | #4 |
Who Changed This?
CJ-428 looks like F*%d nomenclature. Somebody will turn up eventually who can tell you what the CJ means.
03-23-2019, 02:18 PM | #5 |
The CJ stands for chevy truck or Suburban 72 was year I guess the one I used shows 396 in 72 for 3/4 ton suburban I will post the site when I get home what site you all using to decode.?
03-23-2019, 02:20 PM | #6 |
I think the 428 is year code?
03-23-2019, 03:59 PM | #7 |
There is a lot of discussion about decoding engines and transmissions in these threads including discussion about my TH400.
http://67-72chevytrucks.com/vboard/s...hlight=69t+328 http://67-72chevytrucks.com/vboard/s...69t+328&page=3 Do you have a picture of the tag that is riveted to your transmission? I believe the J in the code (CJ) you supplied indicates it is for a big block. |
03-23-2019, 04:57 PM | #8 |
Yes will post later thanks.
03-23-2019, 10:46 PM | #9 |
402 is a 396 bored .030 over. More here----- https://itstillruns.com/history-chev...e-7750247.html
03-23-2019, 11:38 PM | #10 |
http://6454333956132_5222136428946784256_n[/IMG] http://67-72chevytrucks.com/vboard/a...1&d=1553399124
03-23-2019, 11:47 PM | #11 | |
03-23-2019, 11:48 PM | #12 | |
03-23-2019, 11:50 PM | #13 |
http://www.teufert.net/trans/t-400.htm This is the one that had 396 for 71-72 chevy truck
03-23-2019, 11:57 PM | #14 |
03-24-2019, 01:18 AM | #15 |
I think you've pretty much nailed it. I'm no expert (bruceman1968 is), but I'd say the trans is for a big block 1972 2 wheel drive truck, serial number 25605 built April 28, 1972.
03-24-2019, 12:46 PM | #16 |
