03-26-2010, 10:52 PM | #1 |
Rearend Problem???
I have a 2000 silverado 2wd with a 5.3l and a posi rearend. I noticed today when i turn the wheels real hard and sharp my rearend or transmission is grinding and growling??? Any thoughts on this??
03-26-2010, 10:58 PM | #2 |
My Carbon Footprint
Re: Rearend Problem???
You really need to change your diet or try "beno". LOL
03-27-2010, 12:05 AM | #3 |
Right on the line, baby!
Awww man- give a guy a break
He DID say it could be the transmission. I assume you haven't had the cover off yet?
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
03-27-2010, 12:13 AM | #4 |
My Carbon Footprint
BTW.....what part of Or-ee-gone you from?
03-28-2010, 05:01 PM | #5 |
its all about the +6 inches
I would start with new oil and GM dealer posi additive
03-29-2010, 08:24 PM | #6 |
Okay, I dopped it off at the shop that serviced it, I will post you guys what they tell me, once I know. Thanks for most of your replies!
03-29-2010, 09:47 PM | #7 |
with it doing it when turning that leads me to think it might be an axle bearing.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
03-30-2010, 07:57 AM | #8 |
Brakes. Specifically, if you have rear discs, the fist sign of the internal parking brakes being worn to the metal is a grind when turning, usually right for some reason. basically these are a cable actuated drum brake inside the disc brake rotor, and they drag aned wear out, even if not used.
Solution is to replace the parking brake pads, being sure to turn the internal drum of the rotor to the full width of the new pads.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
