09-15-2015, 09:24 PM | #1 |
No headlights,,,
Ok,,,I've got all lights except the headlights. I've checked and rechecked the fuses,,all seem to be fine, got a new switch,,,Not, put old one back in,,,,all lights but headlights,,,,HELPPPPPP, Is there somewhere else I should check?
09-15-2015, 09:28 PM | #2 |
Re: No headlights,,,
Are both headlights blown out? You never know.
You should be following wiring from the headlights back to see where to power is first detected. |
09-15-2015, 09:40 PM | #3 |
Check the dimmer switch. Start by messing with that plug down there and see if anything changes. I highly suspect you will find a bad dimmer switch or an issue with the wiring down there.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-15-2015, 10:12 PM | #4 |
I would also check the dimmer switch. I would then check the headlamp plugs for power using a test light or meter.
09-15-2015, 10:40 PM | #5 |
20' Daredevil (Ret)
A test lamp or multimeter is your friend..... but if I had to guess, I'd say the dimmer switch (or its connector).
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-15-2015, 10:43 PM | #6 |
Old member
Look at the head lights connectors first. Make sure they haven't come off are broken. If I remember the passenger side feeds off the drivers side. if they are good then check dimmer as mentioned. A test light would be nice to have at least.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-15-2015, 10:52 PM | #7 |
Moderator
Most likely the dimmer switch is the culprit when the headlights are the only thing that doesn't work.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-15-2015, 11:32 PM | #8 |
Dimmer switch
09-16-2015, 01:33 PM | #9 |
Ok,,,,damn you guys were right on it,,,,dimmer switch. Put a new one in ,,poooof,,,,they work,,,,,one was alittle dimmer that the other,,,so I clean the connector,,,done. Guys,,,thanks again,,,,Bill
