04-24-2017, 10:08 PM | #1 |
Hey All - Suspension Mod Question - 1 Ton
1 Ton Dual 3800 Chevy 1954
I Believe it to be Mostly Stock - has Helps as it has a Hoist Previous Owner says He had 4000 lbs in a few time . I Think 3000 lbs would be Plenty , No sense Breaking or Bending something. I have only done Bolt on Tweaks Bushings , Anti-Drive Offsets etc. , Sway Bars for Handing etc. Looking at the Weight of a 1 Ton Set Up = Huge Weight to Control , So ? Thinking of Dropping Out the Helper Springs - each side 26 lbs . Currently No Shocks on this Axle - Considering - Variable Spring Assisted Shocks HD Approx. 375-500 lbs Spring Rating Each ..as they Vary . Hoping those would Replace the Helpers & Gain better Ride Control all at the same Timer .. Helpers Currently don't Start to get engaged unless You have 1600 lbs Load . Spring Assisted Shocks x 2 750 lbs - 1000 Lbs - looking for Strong Mounts ( ? ) Input on Spring Assisted Shocks ? Looking for any Info or Others that may have taken Out the Helper Springs ( I Know I would have to get New Shorter U-Bolts ) Any Idea's or Input Thanks Dan |
04-26-2017, 08:19 AM | #2 |
Re: Hey All - Suspension Mod Question - 1 Ton
No One Altered a 1 Ton rear Suspension ?
In anyway , shape or Form ? |
04-26-2017, 12:07 PM | #3 |
i don't understand what you are trying to convey.
what is an anti-drive? what is the timer? |
04-26-2017, 12:58 PM | #4 |
Airbags. I'm talking to my local spring guy to come up with a set for my R30 dually that will ride better, then make up the weight carrying capacity with a set of airbags. That should improve ride when empty yet still handle heavy loads. I had 2600lbs in the bed once and it sat level.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
04-27-2017, 08:30 AM | #5 | |
also Must Run Pump ? Thinking of removing the 54 lbs of Helpers Then adding Spring Assisted Shocks _ so I'd gain back 28 lbs .. I believe it would only Cost about $150.00 to Convert and Gain some Axle Control .. all at the same Time .. , but I'm an Old Timer - LOL https://www.carid.com/monroe/sensa-t...mpn-58510.html My Immediate Issue is vehicle vibration Huge Vibration - comes up through - Chassis , Cab Doors , and Entire Vehicle . Builds from 44 Mph to 52 Where is Gets Insane - then - Gradually gets less to 56 Mph and Gone @ 60 Mph ! 1. I have done the Clutch in and Clutch Out , in Neutral , in Gear standing still - Don't find anything . 2. Tires I have 1 Tire & Rim that will be Exchanging out , but this can't be the Booming Vib that going on .. 3. Vib just seems to Heavy - so - I'm Wondering what does a Brake Drum Out of Balance be like ?_? 4. I Ran Dial Indicators all over the Driveshafts & Joint Flanges .. etc. all seem to be good .. 5. I used Infra Red - Gauge - Digital - CHECKING TEMPS - seeing If anything was Higher or Lower then all the Rest Area's .. ( 1 Brake Drum and Tire ) 28 Degrees High then the Rest .. That doesn't seem Like a Bearing - Brake Shoe on that side drags just a little and same Area - where Current Tire with Issues Is .. Just don't Feel this 44Mph to 56 Mph has anything to do with a Booming Vibration - that Feels like It would Shake Your Dentures Out - If I had them .. ( Any Thoughts ) 6. When I Mentioned Temperature - After 2 Hour Ride and Hauling 3000 Lbs of River Bottom Top Soil , on a Hot Day 82 Degrees. My Axle and Rear Brake Drums where 114- 118 on Axle , 125 -137 on Rear End , Brake Drums - with in 2 min. of Stopping After this Haul - coming in Warm Stopped and Read . Hottest Spot on Brake Drums 148 Degrees - 137 Degree .. Fronts were all Cooler .. --- so --- Once I remove that 1 Tire and put on straighter Rim - Pretty sure those Temps will Even Up . I Thought for sure I going to Find Axle Bearing reading 255-285 Degree , But Nothing even Close .. Only Other Thing I able to think of is ( Back Lash ) way to Far out ?_? - Feels to Me it's Coming from the Rear of Vehicle . Last edited by Port&PolishMan; 04-27-2017 at 09:18 AM. |
05-01-2017, 09:13 PM | #6 |
Up Date _ Looks Like Drive_Line Angles are Off !
Current Engine is pretty much all Hard Mounted = No Adjustments . Hard Mounted everything . . LOOKING TO MOD THE ENGINE & TRANSMISSION - Angles . . ? Here the Issue Eng & Trans need to be Tilted Back more . . Currently 4.57 Degrees on First Driveshaft . Second Driveshaft 2.99 Degrees Plus the Eaton is approx 2.75 in Staggered Off Center like most are . Motor & Trans are on Center Line . ( NOT 3 Degree's ) - Toward the Rear Axle Eaton . . |
