04-27-2017, 08:20 PM | #1 |
Replaced Distributor- Starter making grinding noise
1978 K5 with original 350. Replaced my distributor and did the engine bump quite a few times (a lot) to confirm TDC/compression stroke. Now starter is making loud grinding noise. I'm recharging battery just in case to try again. Starter looks like it could be original though. Should I just go ahead and replace it? Any suggestions would be appreciated. Thanks.
04-28-2017, 09:56 AM | #2 | |
Active Member
Re: Replaced Distributor- Starter making grinding noise
In the past I have also replaced just the solenoid if I suspect it to be the problem and in other instances the starter gear (bendix) if the starter itself is in good shape.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
04-29-2017, 06:40 PM | #3 | |
