04-29-2017, 10:23 AM | #1 |
torque converter
I am about ready to hook the trans and motor together, should I pour trans fluid directly into the converter before I bolt to flywheel. This is a newly rebuilt trans and motor and probably will not run for another 5 months.
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
04-29-2017, 01:10 PM | #2 |
Re: torque converter
Dump at least a quart into it.
04-29-2017, 09:20 PM | #3 |
Yes never run them dry
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
04-30-2017, 06:28 AM | #4 |
All you are tying to achieve is to get the bearing wet .You don't have to fill the converter . Bearings don't like to spin while there dry . The trans will pump fluid pretty quick but until then the bearings can possibly get a little damage to them if there dry .
05-01-2017, 01:30 AM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
All of the above!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-01-2017, 11:13 PM | #6 |
Does anyone think the folks who make TC's put any lube on the internal parts for start up damage prevention ? Would anyone fire up a rebuilt engine without pre-lubing the bearings ? Oh thats right, every one can build an engine.... I often wondered how they balanced TC's...would anyone think they add fluid to this process ? Just wondering....
05-02-2017, 07:40 AM | #7 | |
05-02-2017, 08:14 PM | #8 |
I never pour ATF into a converter.......I see this thread turning nasty
05-02-2017, 10:15 PM | #9 | |
05-06-2017, 03:58 PM | #10 |
I have been debating removing my trany because I couldn't remember if I put fluid into the converter when I installed it, now I wont have to. Thanks for the info. K.E.N.
05-07-2017, 10:41 PM | #11 |
I am one of those guys who does not put ATF in my converter....been doing this since cast iron power glides....never had a comeback because I did not put ATF in the TC...but again, if you want to put ATF in YOUR converter, go for it...Have you ever got a new TC and it has a warning sticker on the TC..."FILL WITH ATF BEFORE INSTALLATION" ? How about that 40 year warranty you get with the TC...does it say to put ATF in the TC ?
