Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-03-2020, 09:56 AM   #1
old51sedan
old51sedan's Avatar
Wiring Vintage Air
I have my VA all installed, instructions are pretty good. I have it done with the exception of the violet wire under the dash that goes to the key switch. It shows the wire connecting to the run side of the switch, then going from the Battery side apparently to the fuse panel. They is no place on the switch to screw this on to, am I suppose to put a spade on then and push them in with the correct wire? I haven't called them because of the weekend, so I thought I would see if someone can help me, I hate to screw something up.
old51sedan is offline   Reply With Quote
Old 08-05-2020, 01:12 PM   #2
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Wiring Vintage Air
I ended up wiring mine directly to a "key on" slot to the cab fuse box. i ran the wire along with the factory harness upper side behind the dash. a very good source is "73-87chevytrucks.com". the factory diagrams are all there. I believe you will want to look at the interior page 2 pdf file.
good luck!
rodstored-72 is offline   Reply With Quote
