Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old Yesterday, 11:35 AM   #26
landarts
landarts
Re: 71 K20 Idaho Edition
OK here are a few pictures of progress on the bed rotisserie/bed cart. I am using some of the scrap tubing I have laying around and making implements or configurations to use two identical motor stands for a rotisserie/bed cart. Both of the motor stands will be connected with removable tubing through the bottom forward pointing out rigger. At some point I will create a second set of implements so that I could possibly rotate it some so I can do bed floor repair. for now I am just making it into a sturdy breakdown bed cart that is higher than usual do to the lower back issue I have.
When completed it will also have a bolt on set of outrigger legs for safety and rigidity. So I bought both of the engine stands from Jegs at $59 a piece. With those and probably around $100 dollars of scrap tubing and a few extra pairs of casters i have I should be into for around $225 - 250. For me to have a tool that will allow me to move a bed around in the shop, work standing up and not have to bend over to work on lower areas, is just perfect. Also will be able to break it down and store under the workbench when not in use.
Her are a few pictures snapped from this morning. The picture that has a few pieces of metal clamped to it and a caster will not have the piece on top, just did that for mockup reasons. Will probably just remove the lower tubing that came with the stand and put a new heavy wall piece there so I can weld a caster plate and have a breakable caster, also allows me to bolt on original when using for a motor.
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
69 GMC 1/2 ton original gold paint
68 K20 4x4 Long bed Stepside
71 K20 Custom 4x4 511 Ochre paint
72 GMC K20 Custom Deluxe 4x4 original paint with pinstripe
72 K20 Custom Deluxe 4x4 original paint with pinstripe
69 K10 Custom package 4x4 (69 K10 from the field)
67 GMC K1500 4x4 number 100 off the assembly line all original paint
67 K10 4x4 short stepside - long term project
72 Cheyenne K10 4x4 557 paint code -SOLD
68 C10 1/2 ton - 68 Second Chance - SOLD
72 3/4 Ton GMC 4x4 - SOLD
68 C25 GMC LWB - SOLD
68 C10 LWB - SOLD
67 C20 - SOLD
71 Blazer - SOLD
72 1/2 ton 4x4 - SOLD
70 CST daily driver - SOLD
72 suburban - SOLD
landarts is offline   Reply With Quote
Old Today, 12:53 AM   #27
Richard
Great work on everything!
Richard
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
