01-16-2015, 09:26 PM | #1 |
Blazer or Suburban hatch arms
I was digging through some stuff in the barn and ran across these hatch arms. The only problem is I can't remember if I took them off a suburban or blazer. Is there an easy way to tell which they fit? I assume they are not the same. The first 2 pictures are of the arms in the down position. The second 2 pictures are of the arms as they have "locked" into place while the hatch is open. Any help would be appreciated.
James |
01-16-2015, 10:26 PM | #2 |
GMCDAC
Re: Blazer or Suburban hatch arms
Hi James, they sure look and measure about the same as my '70 GMC Jimmy, but there may be some differences I can't see.
Nice lookin' pickup! We have a lot of relatives in CO. DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
01-17-2015, 02:46 PM | #3 |
They are blazer arms
01-17-2015, 04:55 PM | #4 |
James |
01-18-2015, 09:21 AM | #5 |
If you look at the post above the top bracket on the blazer hatch has a 90 degree bend that wraps around the hatch. If you look at the pictures in the second link you will see they are flat on a suburban. I did not know they were that close I was comparing them to the ones I saw before that are apparently for barn doors if you look in the first link.
http://67-72chevytrucks.com/vboard/s...light=suburban http://67-72chevytrucks.com/vboard/s...suburban+hatch |
